Random misfire
Old Aug 31, 2016 | 11:00 AM
Faasnu's Avatar
Faasnu
Default Random misfire
I have been getting a small random misfire p0300 code. The CEL turns on and off throughout the day. When it reaches a 1/4 tank of gas, the misfire is gone and the car idles smooth. But as soon as I fill up the tank, idle is shaky and misfire p0300 is back. The car is Vortech supercharged.
Old Aug 31, 2016 | 11:14 AM
jhc's Avatar
jhc
General & Tech Moderator
Could be anything. Plugs, coilpacks, vaccuum leak, bad gasket.
Has it been tuned after the SC install?
Old Sep 2, 2016 | 07:15 PM
Faasnu's Avatar
Faasnu
New plugs, smoke test - no leak. It has been tuned a long time ago.
Old Sep 11, 2016 | 03:51 AM
Trap Star's Avatar
Trap Star
Is it filling up normally at the gas station or does it give you a hard time?
Old Sep 13, 2016 | 09:16 AM
Faasnu's Avatar
Faasnu
Fills up normally. It now shows the misfire code regardless of the fuel level. Sometimes when I drive the car, idle is stable. Other times it shakes between 800-850 rpm.
I cleaned the maf sensor because it was all oily and the AFR became leaner at idle.
The p0300 code jumps from pending (yellow code) to current fault (red).
Old Sep 13, 2016 | 03:12 PM
Trap Star's Avatar
Trap Star
Have you gone through while its happening and disconnected the coil packs 1 by 1 to see if there's an effect? Also could run it for a bit and pull the plugs to check for dampness. You could also try venting the evap canister to atmosphere and see if that makes any difference.
Been chasing down the same code on my car since I got it running, so just throwing out different things I've tried. Mine appears to be evap related but who knows if that will actually fix it. The p0300 has to be the worst, most generic, code ever. It sucks.
Old Sep 13, 2016 | 07:09 PM
Faasnu's Avatar
Faasnu
I disabled the cylinders one by one using a scan tool. They all made car very shaky.
Could blowby oil in the intake system cause p0300?
I have noticed when I changed my spark plugs, the cylinder 4 spark plug had a brown residue where the ignition coil boot seals the spark plug.
Old Sep 14, 2016 | 01:42 AM
MartinZ's Avatar
MartinZ
That's the rocker cover o-ring around the spark plug letting oil through onto the spark plug
Old Sep 14, 2016 | 06:17 AM
rancor's Avatar
rancor
If your talking about this it's pretty normal so have minor staining.
http://www.ngkntk.co.uk/index.php/te.../corono-stain/
mountaineerz
Apr 9, 2017 05:38 PM
hellsoldiers08
Sep 20, 2016 02:44 PM
mazzotta.al
Aug 25, 2016 05:27 PM
Detailed Image
Cleaning & Detailing
Aug 22, 2016 03:49 AM
