No gear indicator after trans-go install
Old Apr 6, 2017 | 07:35 PM
coletrickle74's Avatar
coletrickle74
Default No gear indicator after trans-go install
Finished up my Trans-Go install, everything went 100% fine. Didn't have any issues, triple checked everything along the way. Got it back together with 5 qts to start with.
Turn key on and the display doesn't show Park or any other gears. So it won't start. No codes. Ran through all the gears, mechanically fine it seems. Dipstick is full, checked fuses, did the ECM reset procedure, and even tried rolling the car a little. Unhooking the battery for the night. Anyone have any ideas if this doesn't work?
Old Apr 7, 2017 | 06:41 AM
coletrickle74
Leaving the battery unhooked for 8 hours didn't do anything. Going to check the fuses under behind the battery tonight. Only other spot I can think to check. I really don't feel like dropping the trans pan again
Old Apr 7, 2017 | 08:14 AM
rancor's Avatar
rancor
Maybe you missed a connector inside or outside the transmission?
Old Apr 7, 2017 | 09:29 AM
coletrickle74
Unfortunately there is only 4 plugs on the inside and none on the outside.
I'm hoping for a pinched wire or maybe I routed a harness wrong. Then when I shifted gears something got caught and pulled out of the plug. I dunno, like I said I triple checked everything so I know I connected everything
Old Apr 7, 2017 | 12:52 PM
rcdash's Avatar
rcdash
As I recall it is a CAN connection between the gearshift indicator and the transmission. I suspect the TCM is not getting power or there is a connector off... You may need to take it apart.
Old Apr 7, 2017 | 04:08 PM
coletrickle74
Yep all fuses are good. Going up on jackstands now. 1000% sure everything is plugged in, so I'm not sure what I should be hoping to find.
Old Apr 8, 2017 | 06:30 AM
coletrickle74
Well I was right, everything was plugged in. But I missed the linkage
In my defense there was nothing in the install instructions or the DIY about it. Didn't even see it when I removed the valve body the first time.
Old Apr 8, 2017 | 07:24 AM
nizmo_0385's Avatar
nizmo_0385
Man so happy for you.
Post a vid of you rowing through the gears!!!
I LOVE TRANSGO
Old Apr 8, 2017 | 12:36 PM
coletrickle74
Filled it up, checked for leaks, took it for a spin.
Normal driving you literally don't know it's there. Feels exactly the same. High RPM shifting and you can feel it hit pretty hard. Should be a blast at the track
Old Apr 25, 2023 | 03:50 PM
Mahmoud Sahli's Avatar
Mahmoud Sahli
It happened to me now that when I changed a new engine, I did not find the cause of the malfunctionSame Turn key on and the display doesn't show Park or any other gears. So it won't start. No codes
🤔🤔 any ideas???
Old Oct 24, 2023 | 12:59 PM
Skidofficial's Avatar
Skidofficial
🤔🤔 any ideas???
Did you fix it I’m having the same issue after my car worked for like 3 days
