My 350z SC bogs on full throttle
on
I have a 03 350z SC, I've had it for about little over a year, its been having problems after it was left parked for abiut a good 3 to 4 months with it being started up every now and then, but not really driven. I had it in a paint shop for a little while. When I got the car back, the car wasn't running the same. It bogs right around 3-4k rpm. The bog happens every now and then, its random but it almost feels like I'm driving a turbo and have to slowly get into reving and maybe it will react. I do not think the paint shop had anything to do with the issue.
Sincr I got the car back, I've been working on and off tirelessly to get it running right. I've changed my spark plugs, throttle body, MAF sensor, fuel, fuel pump, cleaned out filter, and I'm just out of options and ideas to why its lagging randomly. It has a very similar symptoms to having a bad MAF sensor.
Slight info to help:
It is a DE supercharged.
Parked for about 3 to 4 months close to winter.
Cleaned out all pipes and changed to new parts (throttle body, spark, filter, fuel pump,fuel, etc)
This is my last resort before I take it to a shop, please someone throw me some information.
what mods are on the car?
what supercharger kit?
are you getting any check engine lights?
if I had to guess ... your BOV is stuck open but this is simply a guess off the minimal details you've put up. I'm usually wrong - so dont bother checking the BOV, vac lines, or intake duct-work...
Did you drain the gas? American gas is only good for 1 week before it starts to spoil. You might have bad gas.
Have you logged the AFR and tune? To see if you're running lean or rich? Before I got my tune and just had a basic base tune my car would bog at WOT due to it pissing fuel into the motor. But I only focused on the idle and cruising RPM's
You might be super lean as well. I'd log the tracers and AFR.
Check for possible leaking injectors, clogged catalytic converters, fouled Wideband sensors, belt slip on supercharger serpentine pulley. Also check for exhaust leaks near the Wideband sensors, it will make it show leaner than the exhaust gas really is.
I ran HFCs boosted with a Vortech for 2 years. And the complete kit is made for a stock 350z/G35 in terms of the out of the box tune. He did say he was supercharged, not saying you are wrong though.
