CD009 compared to CD001
Old May 6, 2017 | 10:50 PM
hulkout's Avatar
hulkout
Default CD009 compared to CD001
Cd009 bushings
Cd001 no bushings.
i finally got around to swapping in a cd009 after years of complaining about grinding shifts. I looked and looked for ways of identification for a cd009. And couldn't find any. The main thing I noticed from looking is my cd001 had a solid mount shifter bracket. The cd009 has rubber bushings in the bracket holes.
Cd009 counter weight.
cd001 no counter weight.
Second is my cd009 had a counter weight or something on it that the cd001 did not. Now these 2 things could be because it's newer or because it came from a G35 which was meant to be softer and smoother. However i did not see either of those things when looking at older g35 transmissions. Just was thinking maybe this could help others out in the future.
Old May 9, 2017 | 04:08 PM
Conway_160's Avatar
Conway_160
What's the casting on the side of the tranny?
Old Jun 7, 2017 | 02:20 PM
ElDatsun's Avatar
ElDatsun
Where did you find a CD009 transmission? I'm in search of one
Old Jun 7, 2017 | 02:35 PM
joeyvq27's Avatar
joeyvq27
cd009 are every where and you know its a cd009 if it says cdo#2 on the side
Old Jun 7, 2017 | 04:44 PM
Conway_160's Avatar
Conway_160
My 2004 G35 Has the CD01 casting on the side but it has all of the items you said the CD01 doesn't have.
Old Jun 8, 2017 | 07:02 AM
travlee's Avatar
travlee
Master
google it lazy ***
Old Jun 8, 2017 | 07:11 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by travlee
google it lazy ***
Yet you just gave him a source. Hahahahahaaaaaaa.... Trav, stay away from those over-the-counter hallucinogens.
For the OP.... another tip: DE-specific versions of the '009 went by Nissan PN 32010-CD009 but has been superseded by Nissan PN 32010-CD00A (if you are searching for a new one).
From these threads:
https://my350z.com/forum/engine-and-...l#post10700084
https://my350z.com/forum/engine-and-...l#post10769601
And there's probably at least another dozen or so threads here on this:
https://www.google.com/search?q=swap...utf-8&oe=utf-8
Old Jun 8, 2017 | 07:13 AM
travlee's Avatar
travlee
Master
dayquill is a hellava drug.. haha
Old Jun 8, 2017 | 12:31 PM
ElDatsun's Avatar
ElDatsun
google it lazy ***
I have idiot
Old Jun 8, 2017 | 02:12 PM
travlee's Avatar
travlee
Master
Says the person who asked where to get one
Old Jun 21, 2017 | 07:15 PM
NISMO87's Avatar
NISMO87
that's not true at all. I've bought and sold many cd009 transmissions that say cd0#1 on the side. I've confirmed them with my buddy that works at nissan.
Old Jun 22, 2017 | 04:22 PM
Conway_160's Avatar
Conway_160
So how will I know if I own a CD001 or 009?
Old Jun 22, 2017 | 04:43 PM
NISMO87's Avatar
NISMO87
best way to know is call concept z performance or a Nissan dealer and give them the vin on the transmission. I just sold one yesterday that had the CD0#1 on the side and it is a cd009 and last week I sold one that had cd0#2 on the side. Nissan started installing the cd009 transmission around mid 2004.
Old Jun 22, 2017 | 04:56 PM
MicVelo's Avatar
^^^This.
Well, it looks like NISMO87 beat me to the punchline while I was looking up the "other thread" I usually reference.
Here: https://my350z.com/forum/engine-and-...l#post10700471
And he's correct. All transmissions up to '07 (HR motor cars) had transmission CASES marked "CD0" and some/not all appended with "#X" (1 or 2). CD0 #1 (or without the "#X" on it) was used - as he mentioned - to end of '05 MY and that common CASE was used for all versions CD001 to CD009 (2005).
Repeat: Only '06 CD009s were marked CD0 #2
'07+ transmissions on HR/VHR (in both Nissan and Infiniti) have a different CASE marked "CD5" and are NOT backward compatible to DE - completely different bellhousing, actuation mechanisms (CSC), tail shaft/yoke (I think).
Old Jun 22, 2017 | 06:37 PM
Conway_160's Avatar
Conway_160
Thanks guys this will same me some money knowing I already have the CD09 and I don't need to worry as much about my syncros.
Old Mar 2, 2025 | 02:54 AM
KenChase99's Avatar
KenChase99
If you’re working with a CD009 transmission and want to ensure smooth performance, it's great to know you’ve got a solid setup. However, if you're dealing with complex data analysis in automotive engineering—such as performance testing, drivetrain efficiency, or material stress calculations—you might need advanced curve-fitting techniques.
SplineCloud offers a powerful curve fitting tool that allows engineers to analyze complex datasets with parametric splines. Whether you're mapping shift patterns, analyzing torque curves, or modeling gear ratios, this tool can help refine your data for better insights.
Old Jun 26, 2025 | 10:12 AM
ernard44's Avatar
ernard44
Old Jun 26, 2025 | 03:14 PM
travlee's Avatar
travlee
Master
says the noob who's mom was prob roofied to conceive you, which she prob should have aborted
SlowZ333
Dec 10, 2022 10:58 AM
Myles_z33
Jul 17, 2020 12:03 PM
maxitoman007
Feb 11, 2020 06:57 AM
