Fuel pump 350z
Old Jun 11, 2017 | 03:16 PM
Joel.osuna15's Avatar
Joel.osuna15
Default Fuel pump 350z
i have an 07 nismo and want a new/ better fuel pump. I had this aem 320lph e85 compatible in mind. Does it fit ? or is there anything i need to change
Old Jun 11, 2017 | 05:59 PM
dcains's Avatar
dcains
What's wrong with the pump you have now? What do you expect a new pump will do for you?
Old Jun 11, 2017 | 09:52 PM
terrasmak's Avatar
Are you converting to E85 ?
Old Jun 12, 2017 | 03:49 AM
travlee's Avatar
travlee
Master
more gas = more fast...... i love these very random noob posts
Old Jun 15, 2017 | 03:17 PM
slicnicz33's Avatar
slicnicz33
If the size and fitings are the same as stock ( diameter and length or height ) then virtually yes it will work with stock housing
I agree with travlee, more fuel = more power, but if you max out the duty cycle of your injectors it doesn't matter how much fuel you can pump , same goes if you max a fuel pump but not the injectors and even fuel rail size, fuel line size , fuel pressure.
Compact body (39mm diameter x 65mm length size of your aem 320 pump
A thread you maybe interested in reading
https://my350z.com/forum/forced-indu...mp-sizing.html
BluestreamDE
Feb 21, 2020 06:14 AM
0taku
Jul 22, 2017 04:07 PM
etkms
Apr 6, 2017 10:15 AM
irishguy0224
350Z Roadster
Mar 27, 2017 07:05 PM
Money1230
Sep 24, 2016 08:22 PM
