Dyno results, your thoughts?
Old Aug 27, 2017 | 01:31 PM
Desert Z's Avatar
Desert Z
Default Dyno results, your thoughts?
Car just turned 100k so I decided to take it to the dyno for a base run. It's a 2006 (track model) Rev up with TB spacer, CAI, test pipes, hr y pipe and DC sports muffler. (It's only the muffler as I got a muffler leak at the last autocross and -on a budget- I decided to have a friend weld in an aftermarket muffler instead of replacing the cat back)
Tuner said it was a healthy motor at 100k miles, specially since it doesn't burn a drop of oil and I autox frequently. He said he dynoed a G35 with less mileage that made 195 rwhp
I feel this is a little lower than I expected but I'm not altogether dissapointed.
228hp @ 7080 RPM, 207 ft lb @ 2700 RPM, untuned. Your thoughts?
Engine bay
Old Aug 27, 2017 | 02:23 PM
jellofuel's Avatar
jellofuel
Which dyno is this? If you tuned for these mods, my money would be you'd make around 255~whp on a dynojet.
Old Aug 27, 2017 | 03:22 PM
BakaN20's Avatar
BakaN20
What gear was the dyno done in? Have you been to a 1/4 mile track before? Trap speeds give somewhat of an indication of power.
Old Aug 27, 2017 | 03:35 PM
Desert Z's Avatar
Desert Z
Yes, it's a dynojet.
An no I haven't been to a drag strip. And i believe it was done in 4th gear.
Got it done at Project Import in Orange, CA.
Old Aug 27, 2017 | 03:53 PM
jellofuel's Avatar
jellofuel
You might make a bit more going back to factory revup air box with a K&N filter, since the '06 box has an integrated velocity stack in it. A tune would help, but this seems to be a low reading dyno. Stock non-revup DE's generally make 225 or so whp on a dynojet, so if a G made 195, then I'd think that's the case.
Actually, if it's understating power by roughly 30whp, you might make 260 or so on another dyno
Old Aug 27, 2017 | 04:10 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Your "sweet spot" for the dyno should have been done in 5th gear as the gear ratio is 1:1 and is optimal for measuring your power output on the dyno.
You have more mods than I did when I first got my 03 Touring. I don't remember the kind of dyno, but I got 255 whp and almost the same amount of torque. Temps were below freezing outside, too. I had about 10k miles on my Z.
Old Aug 27, 2017 | 07:27 PM
Desert Z's Avatar
Desert Z
That was my first setup. OEM box with k&n filter. I will visit another dyno and bring the stock box with me and make sure its done in 5th gear.
I will say that the 3" CAI really freed up the engine in the 5-7k rpm range and I felt that immediately. Engine sounds amazing too. The dyno curve kinda proves that it is breathing well all the way up to redline. I do like the way the power curve looks.
Old Aug 27, 2017 | 08:42 PM
CK_32's Avatar
CK_32
Not to derail, but can anyone link me to the dyno report thread?
I've been googling for like 3 days. I just saw it last week too.
The thread where everyone reports in their set up and the dump numbers they made.
Old Aug 28, 2017 | 03:56 AM
jellofuel's Avatar
jellofuel
I didn't realize that's a 3" - I thought it was an AEM, which is 2.75, I believe? But you can free up some more power up top with a 3" MAF housing, and velocity stack. And yeah, that's a good looking curve, that's what I'm going for on my build.
You would need a retune if upgrading the MAF section.
Last edited by jellofuel; Aug 28, 2017 at 03:57 AM. Reason: Changing MAF section requires tune.
Old Aug 29, 2017 | 06:30 AM
350z006's Avatar
350z006
That does not look like a dynojet dyno to me...based on the dyno sheet...
I used to go to Project Import a long time ago, and last time I was there they definitely did not have a dynojet-type dyno...
Old Aug 29, 2017 | 06:49 AM
iideadeyeii's Avatar
iideadeyeii
This x1000
