RPM wire
Old Feb 20, 2004 | 09:21 AM
ACP's Avatar
ACP
Default RPM wire
Anyone know the correct ECU wire to tap in to get RPM reading ?
thanks
Old Feb 20, 2004 | 09:59 AM
ravaz's Avatar
ravaz
#62. Color is Y/R.
Old Feb 20, 2004 | 10:04 AM
g356gear's Avatar
g356gear
I am assuming that is the crank sensor?
Old Feb 20, 2004 | 10:19 AM
ravaz's Avatar
ravaz
#62 is ignition signal #1 I believe. (the others are #60, 61, 79, 80, 81)
Crankshaft sensor is #13.
I'm using #62 for RPM.
Old Feb 20, 2004 | 11:36 AM
ACP's Avatar
ACP
Thank you ravaz, I tried #13, crank position sensor and it wasn't right
I will try now
Old Feb 20, 2004 | 12:01 PM
ACP's Avatar
ACP
shoot, that isn't the one I need either
I can't get a proper RPM reading on my e-01.....
Old Feb 20, 2004 | 01:28 PM
g356gear's Avatar
g356gear
Something has got to be off on you're set up process. Either of those should give you the right signal.
Old Feb 21, 2004 | 07:42 AM
ravaz's Avatar
ravaz
Yeah that's really weird. #62 works well for me and my friends Z. Let us know how it turns out, I'm curious. How are you tapping in for the signal?
Old Feb 21, 2004 | 02:11 PM
ACP's Avatar
ACP
With one of those red inline wire taps....
Old Feb 21, 2004 | 02:58 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
tim:
you need to use the ignition 1 wire (or any of the 6), and set the e01 to use 1-cylinder operation.. originally the e01 could not do this, but greddy added some "box" or so they told me...
do you know what piece i am talking about?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
350Z_Al
Oct 29, 2020 07:44 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Inspatatrac
Sep 8, 2015 02:12 PM
