Trans/Clutch ....issue?
Old Oct 12, 2018 | 09:49 AM
Kevin Skene's Avatar
Kevin Skene
Default Trans/Clutch ....issue?
2003 350z - 6 speed
3 drift events on new clutch / flywheel (Z1 performance street, 6 puck spring, Z1 Lightweight flywheel)
The last event was my first competition and I qualified 4th, so that's why I kept shifting when it was already feeling sloppy.
HERE'S THE STUFF
I was running DOT 3 fluid (already have SS clutch line and heat wrap). The clutch felt fine all through practice, but as soon as the competition started and I did my first back to back run, I lost my ability to shift and the clutch pedal stayed to the floor. Given that I was using DOT 3 and it felt fine all day up until that moment, i'm going with the fact that the clutch fluid boiled. So I drained the whole assembly, got a new clutch master, new clutch slave and put in some Motul RBF600. I bled the clutch like normal (2 person method), then ran a hose from the bleeder valve on the slave, up back into the reservoir and pumped a million times, just to insure all or any air bubbles moved out.
STILL, my transmission feels really hard to shift in any gear while it's cold. I drove the car about 5 miles on the freeway (it's not a street legal build) and it was still difficult to shift. No grinds per say, but the shifts were far from smooth and I really had to push it into gear. It's filled with Nissan fluid.
Thoughts?
Taiwan Liu
Jul 13, 2018 07:28 AM
kapaobao
Apr 10, 2014 01:31 AM
mgrotel
Feb 7, 2012 05:56 AM
Yancy
Aug 11, 2006 08:25 AM
Firemedic
Oct 25, 2005 01:35 PM
