350z valve tick
Old Aug 20, 2019 | 06:15 AM
Sirawesomeness's Avatar
Sirawesomeness
Default 350z valve tick
Hi. I'm new here. I have a 350z with a loud valve tick on the passenger side. I've heard it can be a gap between the valve and cam lobe. I would prefer not to have to pull the head off
Here is a video of the problem.
https://youtu.be/drXRfa2-ITg
Old Aug 20, 2019 | 06:45 AM
bealljk's Avatar
bealljk
it may be the early onset of bearing failure
Old Aug 20, 2019 | 06:54 AM
Sirawesomeness
Bearing failure? In what?
Old Aug 20, 2019 | 07:27 AM
bealljk's Avatar
bealljk
your engine
Old Aug 20, 2019 | 07:39 AM
Sirawesomeness
your engine
You mean rod bearings? It really sounds like it's top end
Old Aug 20, 2019 | 08:14 AM
bealljk's Avatar
bealljk
many people have had the same noise (as best as I could decipher through a youtube video, through the hood of the car) and many people have spun bearings … I don't know many people that have had valve tick(that was actually bonafide valve tick).
It may be valve noise? If you don't know and/or don't want to jump into the engine than take the car to a knowledgeable mechanic for their opinion and/or drain the oil and check for bearing material and/or have an oil analysis done.
If you can fix this now before the bearing really goes to shot it'll be significantly less expensive to fix verses letting it get worse and eventually failing and furthermore catastrophic failure.
from way back in the day:
from just back in the day:
from a little bit past back in the day:
Old Aug 20, 2019 | 08:51 AM
Sirawesomeness
https://youtu.be/VU4rMFq0Bzc
https://youtu.be/_h7Sc1Sjwu4
https://youtu.be/2Wg1VrQjYZI
I'm sorry for the poor video quality. I'll try to get a better one when i get home. It definitely doesn't sound like the videos you posted
Old Aug 20, 2019 | 10:33 AM
bealljk's Avatar
bealljk
no worries - my piece of advice would be have it investigated. The more information you know from a trusted source the better decision you can make and the less costly the repairs.
Old Aug 20, 2019 | 02:02 PM
Sirawesomeness
Here is an updated video.
Old Aug 20, 2019 | 09:58 PM
813_350Z's Avatar
813_350Z
Sounds like valves/lifters/injectors. I have had that same sound since the day I bought my Z 8 years ago. I put a slightly thicker oil in it and the noise became less noticeable, but it is still there. You can try that to see if it works, provided it is one of the first two things I mentioned.
For comforts sake, I would take it to a mechanic and just have them check it out.
Old Aug 26, 2019 | 06:21 PM
Sirawesomeness
Welp. I'm pretty sure i found the cause of the ticking. Cylinder 3's rear most exhaust valve has an extreme amount of clearance. Probably about a 1/4 inch. What could have caused this and is it fixable?
Here is a video. It may be hard to see tho.
Old Aug 27, 2019 | 05:01 AM
masterjr33's Avatar
masterjr33
measure cam lobe to see if it is worn. then remove cam.and pull valve/spring and check/measure.
Old Sep 1, 2019 | 01:39 PM
Sirawesomeness
I believe i found the issue. I pulled the bucket off the valve and it looks like the inside center is pushed in more than it should
CTS13
Dec 16, 2011 01:43 PM
Jit13
Aug 12, 2009 04:37 PM
bailey bill
Jun 7, 2009 06:16 AM
sry110
Apr 6, 2009 06:30 PM
dan_csulb
Oct 18, 2005 02:49 PM
