370z Nismo Diff on 350z
Old Sep 2, 2019 | 07:46 AM
Pawzer1's Avatar
Pawzer1
Default 370z Nismo Diff on 350z
Hello guys!
Wondering if I could swap the entire pumpkin differential from a '13 370z nismo onto my '06 350z base model. Wondering if is a direct bolt on swap.
Old Sep 2, 2019 | 08:29 AM
mr. sparco's Avatar
mr. sparco
6mt to 6mt rear diff will work. Your speedo might be off a bit since yours is a base model and the stub axles are slightly different in number of teeth.
Old Sep 2, 2019 | 08:58 AM
guitman32's Avatar
guitman32
This question is in the running for most asked question on this board, lol a search will help.
Old Sep 2, 2019 | 09:56 AM
Pawzer1's Avatar
Pawzer1
Yep, both are manual
Old Sep 2, 2019 | 06:32 PM
dkmura's Avatar
dkmura
General & DIY Moderator
This is the correct answer. This will not be a direct swap as the stub axles are different lengths so OP would need them as well.
Old Sep 3, 2019 | 05:05 PM
Enriquez2000's Avatar
Enriquez2000
Ive been looking to do this for 3.7 gears. If the pumpkin comes with stubs in(they usually do) its a bolt on. Ebay has a bunch... just make sure you get the right pinion flange
kurrlyy
Oct 24, 2018 06:15 AM
Driver06
Apr 6, 2011 07:22 PM
dlek00
NISMO 350Z
Sep 10, 2010 05:41 AM
StoneZtech
NISMO 370Z
Apr 11, 2010 12:28 AM
Spec_Tacular
Oct 31, 2008 11:11 PM
