Engine harness help
Old Nov 12, 2019 | 04:21 PM
Jollyroger0612's Avatar
Jollyroger0612
Default Engine harness help
I just got a replacement motor put into my 05 z and I'm having trouble getting the harness routed correctly. Specifically behind the engine. Every way I've tried I seem to be forcing it and connectors won't reach. If anyone has a picture of the back of their de that would be awesome. Any tips would be much appreciated.
Old Nov 12, 2019 | 06:52 PM
bealljk's Avatar
bealljk
likely your neutral position and reverse sensors are short ... just cut them and splice in extra wire...
Old Nov 12, 2019 | 11:13 PM
813_350Z's Avatar
813_350Z
You definitely know more about this than I do, but if they are short, wouldn't it indicate that the routing is wrong? If everything is identical then there should be no issues with wire lengths upon reinstall short of incorrect routing of the harness.
OP, I will try get a pic for you when i get home in the am.
Old Nov 13, 2019 | 03:07 AM
Jollyroger0612
I would appreciate that picture very much. Nothing has changed so there should be no reason to extend wires just trying to figure out the correct routing.
Old Nov 13, 2019 | 06:56 AM
bealljk's Avatar
bealljk
Blind leading the blind!!!
It's hard to say … I can only assume Nissan routed the harness essentially to use the least amount of wire (cost savings times a zillion production cars). When I installed my OEM harness I slopped it in and the transmission sensors were short … I didn't even mess around with it, just extended them.
Old Nov 13, 2019 | 02:53 PM
Jollyroger0612
Thank you so much for the pictures and videos. It really helps. You sir are a saint
Old Nov 13, 2019 | 08:49 PM
813_350Z's Avatar
813_350Z
You're welcome. Hopefully it helps you get everything back together and running properly!
Jrmbong
Mar 8, 2014 03:33 PM
crsracing19
Dec 14, 2013 12:11 PM
BlackOhfour
Oct 2, 2012 09:01 PM
youngmanzy
Aug 6, 2008 11:02 AM
