Water Pump Stuck Without Bolts/ 350z 2004
Old Nov 18, 2019 | 03:53 AM
Yoaris Garc ia's Avatar
Yoaris Garc ia
Default Water Pump Stuck Without Bolts/ 350z 2004
Water Pump Stuck Without Bolts/350z 2004
My husband is having a hard time taking out the water pump. There was a lot of corrosion on the thermostat and lines...we assumed that that's why the water pump is stuck.
He try a lot of things and nothing...
I would like to read your suggestions💡
Thanks in advance.
Old Aug 26, 2024 | 06:29 AM
Lcheca06's Avatar
Lcheca06
Thanks in advance.
just use a crowbar to get the water pump out (be carefull with the timing chain), do not use the long tensioner bolts to get it out cause they are just gonna bend or brake because of the rust on the water pump (mine was +170K miles when i changed it) and then you'll have another problem, it happened to me. Hopefully this helps someone.
Old Aug 27, 2024 | 10:56 AM
Ghoulzee's Avatar
Ghoulzee
Default Water pump bolt broke on me
I tried using a crowbar and still didn’t come out mine has about 198k on it and I struggled for 3 hours to take it out until the bolt broke, any other suggestions to take it out ( I can take out the broken bolt)
Old Aug 27, 2024 | 11:02 AM
travlee's Avatar
travlee
Master
just shy of 5 years on the one and done poster.... good job
Old Oct 30, 2024 | 01:34 PM
Lcheca06's Avatar
Lcheca06
bottom part is the broken bolt, top part is the welded screw and welded washer all together to take the broken bolt out xd.
Well to take out broken bolts you'll need some specialist unless you have a welding machine.
all you need to do is make more room in the engine bay so take out the radiator support and then weld 1 washer to the broken bolt (to make the broken bolt and the washer a single piece) and on top of the washer weld like a 19 or 22mm Bolt head and then maybe can come out its hard to explain but it will come out sum like this.
Adam707
Sep 29, 2019 04:50 PM
bankswood
Sep 11, 2016 03:30 AM
BearJew
Wanted
Mar 9, 2011 01:14 PM
ChopstiX
Mar 15, 2009 09:08 PM
