Quick crankshaft sensor question
Old Nov 18, 2019 | 11:25 AM
carder24's Avatar
carder24
Default Quick crankshaft sensor question
*I know this has been over done but i cant find anything on this specific issue*
2003 Touring Z 6MT
Couple months ago i replaced both camshaft sensors because of the common problem with the VQ35DE blah blah blah.
I bought OEM camshaft sensors and for some wild reason i bought the Autozone CRANKshaft sensor. Shortly after installing these 3 i noticed that when my car is fully warm and i rev it it will come down to about 200-300 RPM's and the entire car will shake for about 1-2 seconds then go back to normal idle. Seems like a vacuum leak or misfire but i recently did brand new plugs (They were due anyway) and checked all vacuum lines everything is in tip top shape but im just having this issue. It also happens when im rolling up to a stoplight and put the car into neutral.
Could it be the Cheapo crankshaft sensor?
*EDIT* Yes ive tried the idle relearn/All reset methods.
Old Nov 18, 2019 | 12:44 PM
travlee's Avatar
travlee
Master
Replace crank with oem, spray brake cleaner around intake connections
Old Nov 21, 2019 | 08:51 AM
carder24's Avatar
carder24
Sensor just came in, ill install it when i get home and clean everything. Update coming
Old Nov 22, 2019 | 05:39 AM
carder24's Avatar
carder24
So its still doing it , Oh well it was worth a shot. I got the codes pulled and i think if i can remember from last night it was a fuel tempature code?
phreaktor
Jul 21, 2019 08:03 AM
shadowm891
Jan 2, 2018 05:57 PM
blazin202
Jun 25, 2014 04:09 PM
RA11325
Aug 23, 2013 06:20 PM
Sebascaris
Oct 27, 2012 06:19 AM
