4th and 6th cylinder dead
Old Dec 8, 2019 | 05:55 PM
Justin9898's Avatar
Justin9898
Default 4th and 6th cylinder dead
4 and 6 not firing
My 4th and 6th cylinder arent firing at all
I checked these
Coil packs and harnesse
Injectors
Spark plugs .
injectors using stethoscope
And compression all 145
I have no idea what else to check help
Old Dec 8, 2019 | 08:47 PM
bealljk's Avatar
bealljk
did you do any recent work involving the engine?
Old Dec 9, 2019 | 01:46 AM
travlee's Avatar
travlee
Master
Nothing... you now have a more economical 4 cylinder
Old Dec 13, 2019 | 07:45 PM
Justin9898's Avatar
Justin9898
I'm going to check vtc next I guess
Old Dec 13, 2019 | 07:46 PM
Justin9898's Avatar
Justin9898
I have a cai plenum spacer too that's all engine wise it didnt do this until I went through a car was it didn't hydro lock I changed everything out that I listed above....
Old Dec 13, 2019 | 07:50 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Gettin' good early mileage with this one...
DYPTDTC?
Justin9898's Avatar
Justin9898
What?
Old Dec 13, 2019 | 09:42 PM
jhc's Avatar
jhc
General & Tech Moderator
DYPTDTC?
Originally Posted by Justin9898
What?
Agreed, that answer's a bit hard to decipher. Perhaps someone can clarify for you, good luck on your project!
Old Dec 13, 2019 | 11:52 PM
813_350Z's Avatar
813_350Z
4 and 6 not firing
I checked these
Injectors
Spark plugs .
I would start by checking CL or another reputable source for an LS1 or LS9 and swap the engine. Not only would it fix the issue you are having, but you can safely run the car through that car wash again without fear of coming out with only 4 cylinders again. You'd be right back where you initially started before this occurred.
Old Dec 14, 2019 | 03:14 AM
MicVelo's Avatar
DYPTDTC?
What?
Guess y’all s not hip to da lingo, man.
I saw no mention of diagnostics so my new acronym introduced earlier this week...
DYPTDTC, pronounced “dipty ditzy”, shorthand for “Did You Pull The Diagnostic Trouble Codes?”
skn5002
Aug 30, 2022 09:32 AM
Tardo
Tuning
Oct 14, 2017 09:54 PM
SurfingRools
Jan 26, 2012 02:15 PM
kajuraelai
Jul 24, 2009 01:53 AM
88G35
Feb 22, 2008 09:15 AM
