Consult ii idle adjustment
Old Sep 14, 2019 | 04:52 AM
Conway_160's Avatar
Conway_160
Default Consult ii idle adjustment
Anyone have experience with the Consult ii? I need to raise the idle of the car to ~900-1000 or set my throttle input to a constant ~1.8%-1.9% input voltage.
I called the local Nissan dealership and they said they said they can only raise the idle +/-100.
Old Sep 14, 2019 | 06:51 AM
jv350z's Avatar
jv350z
no, but have you looked into Uprev. pretty sure it possible (at lest the idle part).
Old Sep 14, 2019 | 09:39 AM
Conway_160's Avatar
Conway_160
I think to buy an uprev is like $300 or something. But i just found
https://conceptzperformance.com/niss...sii_p_6250.php
This is $80 and appears do everything i need and even reset the steering angle. Waiting to hear back to make sure it will raise my limit to ~900.
Old Oct 20, 2019 | 06:14 PM
BakaN20's Avatar
BakaN20
If you have Android, look for a program on play store called car gauge pro. It will allow you to raise your idle, advance timing +/- 2 degrees, a couple other things. If you have a Bluetooth obd2 adapter.
Old Oct 20, 2019 | 06:50 PM
Conway_160's Avatar
Conway_160
Suppose i should have updated this. For what ever reason this didn't work on my car.
Old Oct 20, 2019 | 11:54 PM
BakaN20's Avatar
BakaN20
Try the program I posted. I had to raise my idle in my z since I have a carbon/carbon twin disc and my car would stall out Everytime I press the clutch since the rpms would drop too low
Old Nov 13, 2019 | 07:05 AM
Zach Benedek's Avatar
Zach Benedek
What obd2 adapter are you using?
Old Nov 20, 2019 | 11:26 PM
BakaN20's Avatar
BakaN20
Bafx
Old Nov 21, 2019 | 06:02 AM
iideadeyeii's Avatar
iideadeyeii
Keep the A/C on. That's good for like 75-100rpm
I have to keep it on on my boosted Z or it idles around 650
Old Nov 26, 2019 | 08:26 PM
Scojoturner's Avatar
Scojoturner
Im looking for a solution to for my 2004 (not 2004.5) g35. Need to raise it to as close to 1000 as possible to quiet my Vortech rattle down.
Old Dec 16, 2019 | 07:30 AM
Jollyroger0612's Avatar
Jollyroger0612
Is there an app for iphone?
Old Dec 16, 2019 | 07:42 AM
Scojoturner
I got the Nissan datascan ii with a cheap cable. Raised idle and will also do my data logging with innovate lc2. Awesome
and less than $50
Biochem7
Mar 19, 2023 10:26 AM
Gbastos
Mar 9, 2017 11:53 AM
shadykilla717
Jan 14, 2008 02:54 PM
Zyclone Z
Dec 29, 2007 12:45 PM
gtbuzzbee
Aug 23, 2003 09:53 PM
