Issue Pulling Transmission
Old Jun 2, 2020 | 02:32 PM
Karterde03's Avatar
Karterde03
I love the story’s guys! I’m young and dumb myself haha!
you guys have any tips for pulling the flywheel off? I’ve undone every bolt yet it won’t come off...
Old Jun 2, 2020 | 02:42 PM
travlee's Avatar
travlee
Master
More beer.....
Old Jun 2, 2020 | 02:45 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Well first that clutchy thing needs to be removed.
Then more beer afterwards as an incentive.
Old Jun 2, 2020 | 02:52 PM
travlee's Avatar
travlee
Master
Nobody likes procrastinators......more beer first
Old Jun 2, 2020 | 03:01 PM
Karterde03's Avatar
Karterde03
Oh my guys 😂 I finally did get her off, had no idea there were pins that the plate was held onto. Appreciate the help boys!!
Old Jun 2, 2020 | 03:02 PM
travlee's Avatar
travlee
Master
she faked it.....
Damn I am on a roll tonight
Old Jun 2, 2020 | 03:50 PM
THIRZTY's Avatar
THIRZTY
LOL glad you got er out. My first clutch took my friend and I a couple days... we we're like 16, it was the early 90's places like this on the internet hadn't been invented yet. I had to take advice from my drunk *** home mechanic neighbors... I learned a lot to say the least lol.
Old Jun 2, 2020 | 04:56 PM
calvin.w's Avatar
calvin.w
Rewording got me like:
WOOOOOOOOO
Old Jun 3, 2020 | 07:30 AM
Karterde03's Avatar
Karterde03
Default Stud issue?
Alright now I can’t get the transmission in. Yes I used an alignment tool on the clutch. If I spin the crankshaft pully, I can get the output on the transmission to spin. I just need some helpful insight .
Old Jun 4, 2020 | 10:29 AM
Abog159's Avatar
Abog159
Had the same problem my first time.. Putting in a transmission I mean. Just keep trying.. the splines have to engage just right. You can rock the transmission from side to side (radially) while pushing the transmission in to get the teeth to engage, or you can try spinning the transmission in very small increments from where it mates to the driveshaft. If it doesn't go in, take a break and come back to it when you are fresh. It will take a little force, but not too much or you could damage something. Also, make sure the engine and transmission are axially aligned. This means titling your transmission jack UP towards the engine, and tilting your engine DOWN towards your transmission. How you do that is up to you.. I just yanked on my passenger test pipe (which I left installed) to bring the engine down.
Dummy check before it comes together: Did you lubricate the input shaft? Clutch fork contact surfaces? Throwout bearing? Clean the new pressure plate / flywheel surfaces with brake cleaner? Loctite the Crank bolts? Install new pilot bushing? Replace throwout bearing? Loctite isn't really required, but good practice. If you don't loctite the crank bolts, you are supposed to lube them with motor oil for the torque spec to be meaningful. Hope you get it figured out.
Eazdaskeez
Oct 16, 2017 04:00 PM
omw2fyb
May 9, 2017 03:37 PM
louisville13
Jan 5, 2017 01:31 AM
venture210
Sep 19, 2014 06:20 PM
350zluvr
Jan 20, 2004 08:15 PM
