Whats the deal with NA and the Z's Engine
Depends where you're starting. The VQ35 in the nissan flagship sportscar is already tweaked up about 30hp from the advertised 260hp in the infinity, altima, etc. @ the factory.
Just speculating but I believe BMW would probably be less interested in narrowing the gap between the 330 and their flagship for performance, the M3. It's all about maximizing sales for each market. Therefore that would explain the room for tweaking it for more performance.
I think the question has pretty much been answered.
Besides the "newness" factor, there's the fact that the 350Z's engine is already highly tuned from the factory. It has a great CAI, relatively efficient exhaust, etc.
Your standard 3-series BMW is detuned for comfort, fuel efficiency, noise & vibration reduction, etc. All of these things restrict power production to achieve the cushy, smooth, luxo BMW feel. If you don't care about that stuff (like tuners don't) than significant potential exists to open things up.
I would like to see an actual comparison of dynos of NA 330i and 350z cars; both with the same basic bolt-on mods. I have a hard time believing a 330 is producing 300 RWHP, much less 400 RWHP, with standard bolt ons.
Everyone here seems to understand the question, but the basic premise that the M54 engine is that much more receptive than the VG35 to bolt-ons is unfounded.
EDIT: i realized now i just wrote that headers weren't bolt on mods i don't consider them to be but yes they physicall do bolt onto the engine. Also I just found out the appropriate numbers for the NA BMW it's 315 crank hp...so i was wrong with that...if my math serves me correct that's about 250-260 wheel.
Originally posted by reen
Porting the head doesn't give you more displacement, it allows more airflow. The only mod to a head that could add displacement is increasing the volume of the combustion chamber.
Also you guys have to realize one thing. HP = RPM*TQ / 5252 for every point on the RPM range. Which means that the higher you go over 5252 rpm the more HP you will have holding TQ constant. If an e46 M3 has 333HP it is because the thing revs to 8000rpm. If you looked at the torque graph the 350 has more torqe. If you took some bolt-ons to make a 350 produce 333hp at the crank...their would be a big gap between the torque curve of the M3 versus the torque curve of the 350 (350 being much more). The thing with the m3 is that the engine costs a shitload more...so the internals can handle spinning faster. If you could get the VQ35 spinning up to 8grand...with headwork there would be no reason that it could not hit 400hp at the crank and maybe even at the wheels. Not saying that its possible to get the VQ up to 8grand...just dreaming
...I think people are thinking that because BMWs are considered luxury cars that they can't be tuned...
Now that it has around 150K miles, I'm seriously considering an S50 conversion.
...Also I just found out the appropriate numbers for the NA BMW it's 315 crank hp...so i was wrong with that...if my math serves me correct that's about 250-260 wheel....
Originally posted by genieman17
Not to be a pain or anything, but adding volume to the combustion chamber will NOT give you more displacement. Displacement can only be changed by increasing the bore or the stroke of the engine. Increaseing the volume of the combustion chamber won't do anything except decrease your compression ratio.
However, bigger combustion chamber = more volume between piston and head = greater displacement.
Perhaps displacement is only conventionally measured as bore x stroke; I don't know. Actually, now that I think about it, the very word "displacement" implies a volumetric measurement of the region "displaced" by the movement of the piston.....or bore x stroke.
OK fine.
How do you figure? I'm not saying that this is a good way to increase displacement or that anybody does it. On the contrary -- screwing with your combustion chamber is a bad idea unless you really know what you're doing. I was just pointing out that porting your heads doesn't increase displacement.
OK fine.
OK fine.
The one thing that messing with the heads does is increase flow, which at low rpms may hurt ur power but at higher rpms increases it, so if ur engine were say an s2000 motor, thats where you want it, cuz if you just increased the redline in a 350z without increasing the flow the hp would taper off and increasing the redline wouldn't do anythign except help you blow up the engine faster
liqalu04
Jan 2, 2022 12:58 PM
