What should I upgrade?
Old Dec 9, 2020 | 08:31 PM
ikingian's Avatar
ikingian
Default What should I upgrade?
Hey, I bought my 2006 350z in 2018 and just am now able to put some money into it. The previous owner put a K&N cold air intake and exhaust (don't know which one so if someone could help me figure out how to figure out which one it is, that would be very helpful) on it. The car now has a little over 200,000 miles so I feel like I should be doing some engine upgrades to it since its getting up there but I have no idea where to start so if you guys could help me out, it would mean a lot!
Old Dec 9, 2020 | 11:45 PM
DarkZ03's Avatar
DarkZ03
We need context, what's the budget and goals for the project?
Old Dec 10, 2020 | 01:08 AM
ikingian's Avatar
ikingian
I'm leaning more towards the drift build with some good power. I am not really sure what the budget is somewhere around 5,000 at the moment.
Old Dec 10, 2020 | 06:24 AM
dkmura's Avatar
dkmura
General & DIY Moderator
More context would help. Is this car meant to be a DD or a dedicated drift car? Also, what kind of mechanical skills and tools do you have available?
Old Dec 10, 2020 | 08:08 AM
travlee's Avatar
travlee
Master
good power with a $5k budget on an old tired car wont happen. i would get the stock motor and suspension right, add rjm clutch pedal, and then worry about power adders
Old Dec 11, 2020 | 01:37 PM
Atreyu'z 350's Avatar
Atreyu'z 350
You can do a compression/leakdown test and see what your number are. That would give you a general idea of the health of the valves and the piston rings. But you still have journal bearings and a timing chain to think about.. No odd noises from the engine I'm assuming. Honestly, I would just ride that engine out as is until the end, perform timely routine maintenance on it and address any leaks. And as long as the frame isn't rusted to hell to where it would compromise structural rigidity and be a waste to throw money into, I would do the suspension upgrades like mentioned because parts like that will still be there after you replace an engine or a transmission.. You've got 5k. I'd put most of that aside for a used, low mileage JDM engine replacement and work on the suspension, brake, body and interior upgrades.
IceyZ33
Mar 17, 2020 10:51 AM
christob90
Tuning
Apr 8, 2015 08:21 AM
albertsZ
Intake
Nov 28, 2012 11:01 PM
Mystic929
Sep 2, 2006 10:59 AM
fireballtaft
Dec 20, 2005 07:23 PM
