Full Finned Differential on an 03 DE
Old Dec 22, 2020 | 05:26 AM
zirasx2's Avatar
zirasx2
Question Full Finned Differential on an 03 DE
Hej guys, Finally doing some winter work on my 03 DE, German Import to Sweden. I saw the finned Diff cover on the car. But once it was up, I found that the entire diff is finned. I wasn't expecting that as most pics I've only seen finned covers.
Doing some searching on here/Googling...not finding much on a full finned diff. Anyone know the story behind them? Was it a Nissan option or a euro spec thing?
Old Dec 22, 2020 | 06:14 AM
DarkZ03's Avatar
DarkZ03
That's interesting, never seen it before.
Old Dec 22, 2020 | 10:59 AM
Kwame's Avatar
Kwame
I believe it was a UK OEM spec if memory serves me correctly. I researched this over a decade ago. Unfortunately, I forgot most of the specifics of what I had found.
Old Dec 22, 2020 | 03:24 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
S'far as I recall, this is an R200 like any other but the fin'd model were sold in hot operating climates, e.g., UAE, parts of Africa and I'd bet in parts of Europe. Only time I've seen this referenced though was in/on Z34s so can't say for sure how it ended up on your 33.
Old Dec 23, 2020 | 07:29 AM
dkmura's Avatar
dkmura
General & DIY Moderator
That's an intriguing option for euro-spec Z33s! If you change the diff fluid, be sure to let us know if there's a difference in sump capacity.
Old Dec 23, 2020 | 12:51 PM
zirasx2's Avatar
zirasx2
Will do. Already bought the fluid (80w90 GL5) and cracked the filler bolt...I will drain it after Xmas and let you guys know capacity. I wonder what that little "****" that comes down on passenger side (its not in the middle) on the diff is for? Some kind of catch for metal deposits? Just odd looking.
Old Dec 23, 2020 | 01:14 PM
MicVelo's Avatar
Jacking point. Jacking on the fins will break them.
Old Dec 23, 2020 | 02:15 PM
zirasx2's Avatar
zirasx2
Cool
You think? It went thru my mind, but was thinking when I lift both wheels off the ground...to have it all balancing on that one small contact point? Was worried about the car tipping. I jacked it up on the fins with a rubber pad between. Maybe I'll give it a shot next time...see if it's balanced.
Old Dec 23, 2020 | 02:19 PM
travlee's Avatar
travlee
Master
Throw a 2x4 between jack and diff
Old Dec 26, 2020 | 08:13 AM
terrasmak's Avatar
More info is somewhere on this site, basically came on cars that were commonly used on the autobahn to reduce dif heat.
Old Mar 8, 2021 | 02:24 AM
zirasx2's Avatar
zirasx2
Hej guys, just an update...this thing...
Is a jack point...after I changed the diff fluid...I brought the car down using it...was balanced just fine. Another wierd thing with this diff...car was level...it took almost a full 2 quarts before it started to drip from the filler. I was expecting it to only take 1.5 quarts. Just a heads up for the next guy with one of these diffs.
Z
Old Mar 8, 2021 | 10:23 PM
OldManZ350's Avatar
OldManZ350
That is the Euro-Spec Diff
I have one!
YES, that is the Jack Point.
Z
Old Mar 11, 2021 | 06:10 PM
The_Laughing_Man's Avatar
The_Laughing_Man
2 quarts is normal for the differential.
BPRacer
Tuning
Nov 20, 2014 11:32 AM
fergraz
Puerto Rico
16
Dec 17, 2007 11:59 AM
sandro1313
Feb 18, 2007 11:18 PM
mdang
Europe
May 30, 2004 04:55 AM
fastmike
Europe
Apr 10, 2004 10:57 AM
