Sudden oil dump, all of it
Old Mar 12, 2021 | 07:26 AM
Z little Z's Avatar
Z little Z
Default Sudden oil dump, all of it
Ok, This have happened to me before twice. First time was an oil filter that I never bought before (f*** STP, am a Fram fan) Second time it was a bad oil bolt. Both times the oil light never came on.
This time it did, drove 2 miles after an oil change and the light came on so immediately pulled over. Was late at night and couldn't see anything. Went back the next morning and both the filter and oil bolt were intact. Also noticed a lot of oil spray on mostly the front middle part of the engine bay. It even got on the serpentine belts. Put 4.5 liters of oil and changed before 2800 miles. Never had a serious oil consumption issue.
Car has 183,000 miles/ 294501 km
Old Mar 12, 2021 | 08:16 AM
terrasmak's Avatar
Fram is the last filter I would ever buy, stp is a much higher quality unit. Maybe the oil cooler o ring is going bad, it’s common with age, could also be operator error as I’ve never had this happen
Old Mar 15, 2021 | 09:51 AM
Z little Z's Avatar
Z little Z
Update: had a mobile mechanic show up, essentially the rubber ring from the oil filter glued on. Add new oil filter and it will hit the fan. Z is fine and well, am nursing my bruised ego.
Old Mar 16, 2021 | 06:31 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Bottom line- always make certain the oil filter mounting flange is clear and clean before screwing a new filter on.
gti303
Dec 18, 2007 02:54 PM
Das350z
Jul 23, 2007 07:10 AM
Burrito06
Jul 27, 2006 11:50 AM
stealthrapt0r
Dec 25, 2002 10:36 AM
