08 Auto trans issue
Old Apr 2, 2021 | 02:27 PM
Austin Bohannon's Avatar
Austin Bohannon
Default 08 Auto trans issue
I have a 2008 auto Z. After driving car for 5-10 minutes when in drive coming off idle between 600-1200 rpm it has a hesitation and bogs down the engine. Only when load is on the trans. I can put in park/neutral and revs fine. And car shifts out fine once moving. Just wondering if anyone has ever ran into this issue. I’m leaning to torque converter is getting hot and trying to lock up. Only does issue when warm and been driven for a bit. Any help would be great
Old Apr 2, 2021 | 05:31 PM
travlee's Avatar
travlee
Master
Has the fluid ever been changed?
Old Apr 2, 2021 | 05:32 PM
Austin Bohannon
Trans flush 20k ago
Old Apr 2, 2021 | 05:48 PM
travlee's Avatar
travlee
Master
How many miles total
Old Apr 2, 2021 | 05:52 PM
Austin Bohannon
199xxx. Car has always been serviced at Nissan for all recommended Maintenance
Old Apr 5, 2021 | 07:55 AM
rancor's Avatar
rancor
There is a possibility that this is from the exhaust valve timing clutches but that shows up during warm up and should go away when fully up to temp. You apparently can disconnect the solenoids and if the problem goes away you need to replace the VTC covers. Disconnecting the solenoids will throw a check engine light. Other options could be vacuum leaks. The linked thread also suggests EVAP purge solenoid if it's happening when fully warm and you are having other issues.
https://my350z.com/forum/maintenance...arm-up-39.html
19particles
Drag
Feb 20, 2012 07:38 PM
F34RL355
Sep 21, 2011 05:41 PM
dudegetalife
Jun 10, 2011 09:54 PM
SILKZ03
Pacific
Jul 26, 2008 03:57 PM
Fo350z
Oct 14, 2006 05:17 AM
