350z misfiring again!
Old Mar 16, 2022 | 11:09 PM
Edgar___C's Avatar
Edgar___C
Default 350z misfiring again!
It’s started to miss fire after I change my mufflers (temporary). I’m running with test pipe, stock HR Y-pipe that’s welded straight pipe. It only misfire early when i turn on the car and drive right away. it won’t let me push the much power when i press the full pedal but the issue stops right after a little bit amount of time (1 to 2 min), it will run normally fine at the end. Should I be worry about it and take it to the shop and get it repaired again about the misfire?
DeusExMaxima
Oct 23, 2018 01:01 PM
styy81
May 6, 2011 10:28 PM
tonyzz1e
Wanted
Feb 25, 2011 06:36 PM
leg killa
May 18, 2009 06:50 PM
FALLEN1z
Feb 3, 2007 03:26 PM
