350z not starting
Old Jul 27, 2022 | 01:59 PM
AwpV1's Avatar
AwpV1
Default 350z not starting
Hey was looking to get some help on my 2002 350z it currently has 100,000km. A few months ago From time to time I would have trouble starting the car, it would crank but not start and sometimes when it would start you would hear a mini growl from the car and then instantly die. I replaced the crankshaft sensor and it got better for a few months but recently the same issue has been occurring where the car would start but then instantly die and then take a few tries to start again. Anybody have any clue what the problem could be.
I’m thinking it’s the fuel pump just need a second opinion
Note: I replaced the battery March this year
Thanks in advance
Old Jul 28, 2022 | 03:10 AM
travlee's Avatar
travlee
Master
my guess would be cam shaft sensors
Old Jul 28, 2022 | 06:43 PM
MyZ4U2C's Avatar
MyZ4U2C
My 2003 was doing the exact same thing you describe. I took it in a couple weeks ago as it left me stranded at a stoplight but luckily fired back up. Anyway the bank 1 camshaft sensor was shot and i elected to replace bank 1 and 2 camshaft sensors and the crankshaft sensor as well and it runs better than ever. If you need to replace any one of these 3, then you should replace all 3 and with OEM/Hitachi sensors nothing else.
Old Sep 30, 2022 | 09:22 AM
kenny0469's Avatar
kenny0469
im having the same issue i have seen you on a couple other post so i wanted to ask im having a problem starting my 04 convert Z it cranks but wont start replaced my cams it started right up then right after driving i turned it off tried to start again and it wouldnt start i have codes for 02 and my evaps clogged just bought another putting it in soon what do you think the problem could be
Old Sep 30, 2022 | 09:37 AM
MyZ4U2C's Avatar
MyZ4U2C
Did you only replace the cam sensors? If so, try replacing the crankshaft position sensor as well. The O2 and evap may cause it run a little poorly but i wouldnt think it would prevent from starting. Try the CPS.
Myzteke
Jun 8, 2017 02:45 PM
dj_saki
Jul 11, 2013 03:15 PM
solidfish
Apr 1, 2010 03:11 PM
Stailey
Oct 29, 2008 03:55 PM
stereoneeds
Oct 10, 2008 06:53 PM
