Random DE P0300
Old Feb 15, 2023 | 07:49 AM
bre240z's Avatar
bre240z
Default Random DE P0300
2004 Z MT with about 104K miles. I randomly get a P0300 but only when the car has sat for a few days with out starting it. It'll start up with a rough idle and then the idle is fine after a minute or so. I have a UltraGauge which reads many things like engine temp, volts, MPG etc and also reads engine codes (mainly the reason i have on the car). I daily drive this car and I never get the code when im driving it daily. I clear the code and does not come back on. Car runs fine with no issues. As for mods car has Greddy catback, JWT pop charger everything else is stock. I dont drive the car hard. Only other time it gave me a code was when one of the ignition coil went out. I replaced it with a new one and code was gone but that was a while back. What do you guys think?
Old Feb 15, 2023 | 08:38 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
You likely have another coilpack going South.
Exact same experience. I got lucky, when the DTC showed up it showed the exact cylinder, eg, P0304 instead of “random P0300”. Replaced ‘em all anyways. Cheap. OE units for about $125.
Old Feb 16, 2023 | 08:02 AM
bre240z's Avatar
bre240z
thanks thats what i was thinking but since it hasnt given me an exact cylinder number im not sure if that will be the issue. Im hoping i will since its an easy fix and not expensive. I did think of just replacing all of them all together.
フェアレディZ
NA Builds
May 12, 2022 04:03 AM
BostonZ23
May 25, 2017 11:45 AM
eyeSea
Aug 1, 2013 08:18 PM
Zlut
Oct 3, 2012 08:36 PM
BoOsTedz33TT
Jun 18, 2006 02:27 PM
