So, I've noticed that my clutch is very hard to depress. Probably because of the previous owner resting his foot on it 24/7 but when I'm at a stop, and release the clutch, a very annoying sound starts to occur when clutch is released and stops when I depress the clutch. I've had this problem before on my S13 but am not sure if its the same problem seeing that the Z is much newer and technical. So I'm guessing the tranny needs to be pulled and the TOB needs to be replaced or something else. Any input is appreciated! Thank you.
i cant hear the sounds in the video because i am at work, but by the description it sounds like it is flywheel chatter... our cars sound like cement mixers. he may have an after market clutch (would explain the stiffness) and a light weight flywheel (which would cause the chatter)
Thanks for the input! I appreciate, I'll look more into it tonight and give you guys an update soon.
Alrighty then, I appreciate the input Spike! I will keep you guys updated as soon as I get the parts and drop my tranny. Hopefully the tranny drop and everything will go smoothly.
