Oil Temp sensor location
Old Oct 10, 2024 | 12:47 PM
Mattedg_man's Avatar
Mattedg_man
Default Oil Temp sensor location
Hi All,
Going to be installing an oil temp gauge and was curious where people are placing their sensor at? My two thoughts are either as close to the pickup as possible (either on the oil pan or on a pan spacer), or on a sandwich plate between the oil filter. The sandwich plate seems the easiest but since that has coolant running close to it I'm wondering how accurate/useful the reading would be.
Thanks
Old Oct 11, 2024 | 06:26 PM
Whiskers1996's Avatar
Whiskers1996
I have all extra coolant passenges deleted and run the oil temp through an oil pan spacer.
Old Oct 12, 2024 | 04:14 AM
Aeneas137's Avatar
Aeneas137
Originally Posted by Mattedg_man
Hi All,
Thanks
there's a 1" oil pan spacer available from Z1/CZP That adds about a quart of oil and includes taps for an oil cooler which you can optionally use for a gauge. The oil filter is not the best location for reading the oil temperature. down in the pan near the oil pickup is a more accurate temp. but it might not make much difference. I personally just don't like the fitting near the oil filter because it's exposed.
uberdude
Mar 6, 2024 07:41 PM
pez1111
Jun 21, 2011 04:35 PM
shakuya88
Feb 18, 2011 09:29 PM
Ataru074
May 8, 2009 07:02 AM
lovetoclown
May 18, 2004 05:28 PM
