Unorthodox Crank pulley install?
Old Mar 26, 2004 | 08:38 PM
Ricky's Avatar
Ricky
Default Unorthodox Crank pulley install?
Any Unorthodox Crank pulley install threads out there? My search function isn't working.
If not, can you guys with it, or who know about answer these questions for me:
What tools are needed?
How long did it take?
Is it hard putting on the belts and such due to the tension of the belt?
Thanks in advance.
Old Mar 26, 2004 | 09:55 PM
scubasteve's Avatar
scubasteve
Easy 30-45 min install. Takes longer to take everything apart. Just follow the instructions on the page that the pulleys come with and you'll be fine. I had no problem removing the crank bolt with my dad putting the car into 6th (or something) and mashing really hard on the brake. Very easy job to DIY.
Old Mar 26, 2004 | 10:21 PM
isalvus's Avatar
isalvus
you need a long breaker bar with a deep 19mm socket for the crank pulley and about 150 ft/lbs of torue to loosen bolt
Old Mar 27, 2004 | 04:14 AM
MustGoFastR's Avatar
MustGoFastR
What about installing it on a car with automatic trans?
Old Apr 4, 2004 | 08:13 AM
kopo's Avatar
kopo
i heard thats a real pain in the ***
Old Apr 4, 2004 | 09:56 AM
MustGoFastR
Just found out you can do it with a chain wrench and a friend. Use the chain wrench to wrap around the pulley and have someone hold it while you break the bolt loose.
Old Apr 4, 2004 | 10:12 AM
CaneZMD's Avatar
CaneZMD
That bolt is ridiculously tight. I broke a socket yesterday trying to get it off. I used about a 2.5 foot breaker bar and broke the socket. Oh well.
I think I'll go to sears and by a craftsman socket so when I break that one I can just return it.
Fixxxercask
Nov 9, 2015 11:10 AM
