First oil change??
Old Mar 29, 2004 | 04:49 AM
bigwes's Avatar
bigwes
Default First oil change??
Hey guys,
I just turned 3000 miles on my '04 superblack z. I am going to change the oil and filter myself. Any suggestions on filter type and oil type for a moderate daily driver.
Thanks in advance ,
bigwes
Old Mar 29, 2004 | 07:04 AM
yobri's Avatar
yobri
The filter and oil are all a matter of preference (you'll get the whole gamut of filter selections from board members...), but just let me keep you apprised of the first oil change... that filter is on TIGHT! A lot of us had to tap the filter with a screwdriver to get it off, unless you buy a Nissan OEM oil filter wrench (I broke my old oil filter wrench on my first).
Thought I'd let you know.
Old Mar 29, 2004 | 08:11 AM
bigwes's Avatar
bigwes
Thanks, overall is the process fairly easy. from start to finish.
What weight oil do you use??
Old Mar 29, 2004 | 08:22 AM
yobri's Avatar
yobri
The process is very easy, if you've ever changed your oil yourself before. The undercovering is a bit of a PIA to have to remove (some can change the oil with the cover on, most people can't... too messy).
Recommended weight (as per Nissan, your Owner's Manual should illustrate this) is SAE 5W-30. Be sure to have 5 quarts available.
Good luck, it's nice to bond with the car this way
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
