NISMO LSD Break in procedure???
Well gang, finally got my Nismo GT Pro LSD installed this past weekend, and was hoping somebody here would help guide me on proper break in procedure. The manual says to drive 180 miles at 20mph in figure 8's. I did that for about 4 hours until I realized that I hadn't even come close to the manuals suggested break in period. This is crazy, could it be correct that you have to break it in this much mileage and low speed?!?!!?
I tried searching for info related to this, but of course just when I need it, the search doesnt work!!
https://my350z.com/forum/showthread....threadid=67011
Hey, Kaaz's website has a awesome how to on the break in process. Also does a good job of explaining just how important it is. I don't have it book marked, I'll try and find if for you on yahoo or google.
Thanks, saw that already, it's says why it's important which is good info....but...I was more hoping to hear from somebody else that has installed the Nismo LSD. Maybe somebody from Performance Nissan parts could chime in here???
What did you do to break yours in? At what mileage did you change the fluid for the first time? Has anybody heard first hand from Nissan how to get this thing proper for hard & heavy use?
"We understand that most car owners who use the mechanical L.S.D. are very disturbed by the chattering noise. As mentioned previously, the chattering noise comes from the friction between the clutch plates. This situation is normally caused by not doing enough break in and bad angle fit between the clutch plates."
"The best to break in and remove the noise is by driving in a “figure 8” pattern as shown below for about 30 minutes and let the plates rub in to form a good fit. If this initial break in is not performed and too much torque is applied to the L.S.D. at once, the plates will form strange angles. Then the chattering noise will continue and may even cause damage to the L.S.D."
"The oil used in the L.S.D. could also contribute to the noise problem. Poor quality oils contain large amount of tiny grains of metal which cause chattering noises. If noise still occurs after break in, try changing the L.S.D. oil. This usually eliminates or reduces the noise. Oil which contains large amount of added chemicals will cause noise too. "
Originally posted by g356gear
Try doing it for 30 min straight.....thought I was gonna hurl.
Originally posted by zillinois
Please report back and let us know how it went. Quiet is good.
Thanks guys...
bcoffee20
Nov 19, 2015 06:39 PM
