PSI indicator & Brake warning light... need help!
Old Apr 1, 2004 | 10:45 PM
maximumsportZ's Avatar
maximumsportZ
Default PSI indicator & Brake warning light... need help!
Well I just finished installing my Injen CAI connect the neg back, reset the ecu, then started up. I get the psi warning and the brake warning light is on.. car runs fine injen sounds sweet.
but does anyone know how come all of a sudden these indicators just came on??
Old Apr 2, 2004 | 12:50 AM
UsafaRice's Avatar
UsafaRice
Default Re: PSI indicator & Brake warning light... need help!
Did you remove any spare vacuum lines to make room or anything during the install?
The intake should have only had you disconnect and reconnect the PCV breather.
If you're getting a brake indicator, maybe you knocked a vacuum line loose that feeds the brake booster. I'm not familiar with the brakes power assist and my car is parked too far away right now to check.
I'd just look for loose hoses around the install area. That would be the nice easy fix.
Old Apr 2, 2004 | 01:20 AM
ZRAYGO's Avatar
ZRAYGO
I get the same thing....thought i was seeing things at first...
Old Apr 2, 2004 | 06:06 AM
maximumsportZ
My mistake, it was in the PSI light and the psi indicator, I'm going to go fill them up. I think they're below 28.
apex locator
Jul 23, 2021 02:27 AM
