JUN flywheel
Old Apr 10, 2004 | 09:21 PM
TheBigShow's Avatar
TheBigShow
Originally posted by mode101
would this flywheel help with the throwout bearing noise the Z has (clutch in = quiet, clutch out = grinding) ?
lol; u sound like my dad. he was talkin about that the other day.
goto www.sgpracing.com for the jun.
Old Apr 10, 2004 | 09:29 PM
TheBigShow's Avatar
TheBigShow
so if i get a jun flywheel, what's a good clutch to put on with it?
Old Apr 10, 2004 | 10:32 PM
3rdpower's Avatar
3rdpower
Try JWT clutch and pressure plate w/ JUN.
Old Apr 11, 2004 | 06:16 PM
TheBigShow's Avatar
TheBigShow
u want me to try this because u don't know if it'll work?
Old Apr 11, 2004 | 11:02 PM
jreiter's Avatar
jreiter
Originally posted by Jason@Performance
depending on the clutch...
I see a lot of people replacing their clutch when they get a lightened flywheel. Why is this? What is the advantage of these aftermarket clutches vs the stock clutch? Do they simply have a higher clamping force and thus allow less clutch slip? Does the stock clutch actually have a slipping problem?
Old Apr 12, 2004 | 09:33 AM
Enron Exec's Avatar
Enron Exec
I just called SGP and the JUN flywheel will only work with he stock clutch at this moment. There are no clutches on the et for the Z33 he said. The JWT clutch we see is actually for the Z32 but the JWT flywheel will accept both bolt patterns from the Z32 and Z33. So this is why you need the JWT flywheel if you get the JWT clutch. The SGP guy says they prefer the JUN chromoloy design because the weight of the fly wheel is better distributed versus the aluminum flywheels, like the JWT. The better weight distribution results in little or no chatter.
He summed it up for me by saing if you stick to NA, get the JUN flywheel. If your going FI, as it stands now get the JWT combo or the JWT flywheel and RPM clutch combo.
I would rather have the JUN flywheel and the RPS clutch for my ATI setup but that just isnt possible right now.
Old Apr 12, 2004 | 10:07 AM
TheBigShow's Avatar
TheBigShow
so where the f r the z33 clutches?
Old Apr 12, 2004 | 10:09 AM
mode101's Avatar
mode101
Bigshow; did you and your dad think the new flywheel would help with the noise?
Old Apr 12, 2004 | 10:40 AM
TheBigShow's Avatar
TheBigShow
nah, he noticed it and told me about it. i was like, i dunno.
Old Apr 12, 2004 | 11:46 AM
Enron Exec's Avatar
Enron Exec
I dont understand what your asking.
Old Apr 12, 2004 | 12:04 PM
TheBigShow's Avatar
TheBigShow
i'm askin that there is no clutches that will fit the oem bolt pattern.
Old Apr 12, 2004 | 12:07 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
JWT / NISMO clutches both fit the OEM pattern...
Old Apr 12, 2004 | 03:02 PM
3rdpower's Avatar
3rdpower
I wouldn't advise if it didn't work
Of course it works... as stated - bolt patterns work for OEM.
JWT clutch and pressure plate work just fine w/ stock set up hence will work with JUN flywheel.
Old Apr 12, 2004 | 03:56 PM
Enron Exec's Avatar
Enron Exec
Are you saing i can have the JUN flywheel and the JWT clutch?
Dr.Paulyy
Jul 29, 2019 07:45 AM
RyansZ33
Sep 15, 2015 05:54 AM
