Apexi SAFC II + Honda S2000 Engine Start
Old Apr 10, 2004 | 05:41 PM
Phatmitzu's Avatar
Phatmitzu
Thumbs up Apexi SAFC II + Honda S2000 Engine Start
Just got my carbon fiber trim plate done with the Apexi SAFC II mounted. 3 hours well spent. Also installed the S2000 engine start. Pix...
As you can see I have removed the nav door for the SAFC install. But theres still a gap on the top where suppost to be the door. Any idea on what I should use to fill that space? I have thought of using the same CF plate, but that part isnt flat, so it will be a pain trying to flush the plate against the back. Any better ideas??
Oh yeah, the S2000 engine start works like a charm.
Old Apr 10, 2004 | 06:02 PM
ypwpat's Avatar
ypwpat
COOL!!!!! Nice work but it's a pity. If i were you i won't remove the NAV door IMO! But your S2000 Engine start button is VERY Nice !
Great Job
Old Apr 10, 2004 | 06:04 PM
ThoughtZ's Avatar
ThoughtZ
nice i like the start button but why that location for the placement? just wondering
Old Apr 10, 2004 | 07:41 PM
kgb's Avatar
kgb
Default Re: Apexi SAFC II + Honda S2000 Engine Start
I also had my SAFC II installed today. We removed the two phillips head crews holding plastic piece just forward of the floor in the nav compartment. With it out, we feed the cable through the opening over to the passenger side where the computer is. The excess cable was stuff inside the opening. The tech cut the plastic piece on one side to accommodate the SAFC cable. He then mounted the SAFC in the nav compartment using the hardware it came along with some velcro. It looks very good.
Old Apr 10, 2004 | 08:37 PM
Phatmitzu's Avatar
Phatmitzu
I cant find a better place to mount it.
Old Apr 10, 2004 | 09:04 PM
35oZephyR's Avatar
35oZephyR
Nice phatmitzu...
You're interior is coming along nicely...i'm inspired.
I might have to ditch the idea of having a monitor in the NAV compartment.(stupid 04 nav compartment!)
Might just have one in the Double DIN area using a Kenwood/ Eclipse...then eventually putting the boost controller/ manage inside the NAV when the TT goes in.
Nice job with the s2000 start up button too!
Old Apr 10, 2004 | 10:39 PM
shimz350z's Avatar
shimz350z
phatmitzu yes!!!! finally a z with a engine start button!~
hey...was the installation hard?
Old Apr 10, 2004 | 11:03 PM
D'oh's Avatar
D'oh
So, what is your key ignition like now? Do you still have the start position, or did you lock it out somehow? If you have it, does it start the car too, or does it just do nothing?
Very cool though.
-D'oh!
Old Apr 10, 2004 | 11:51 PM
VQ35Kompressor's Avatar
VQ35Kompressor
Sweet! Nice job man!
Old Apr 10, 2004 | 11:57 PM
Phatmitzu's Avatar
Phatmitzu
Very cool though.
-D'oh!
The installation was simi-hard. Everything works the same if I start the car with the key. Clutch pressed, turn key to on position, crank.
But if I decide to start the car with the engine start button, is basically the same, turn key to the on position, instead of crank it start, I just press the button. I bypassed everthing, meaning I dont need to step on the clutch for me to start the engine with the start button. I wanted to do that because it will be easier for me if I need to start the car from the passenger side.
For safety, I had it hooked up to the handbrake, so it will only work with the handbrake pulled. Just in case while driving the passenger decides to find out what does it do...
Oh, and its got a backlit. It will only light up when its in functioning mode(when the handbrake pulled and key turn to the on position).
Old Apr 11, 2004 | 12:35 AM
mgl's Avatar
mgl
nice work.
so can you put the navi door back on if you wanted to??
Old Apr 11, 2004 | 02:13 AM
spazpilot's Avatar
spazpilot
I personally really like the shift **** and the kenwood
Old Apr 11, 2004 | 02:26 AM
o snap its eric's Avatar
o snap its eric
isnt that dangerous if someone wants to steal your car?
Old Apr 11, 2004 | 02:39 AM
FLYER's Avatar
FLYER
is the apexi safc 2 easy to install and tune...
where is the computer located....!
Old Apr 11, 2004 | 03:31 AM
Z350Lover's Avatar
Z350Lover
Very nice and thoughtful mate!
And yes... how do you actually tune the safc? and where about do you wire the wire to? into the engine bay or just to the passenger side? (basically the same question as what FLYER asked)
cheers,
richie
Old Apr 11, 2004 | 12:25 PM
Phatmitzu's Avatar
Phatmitzu
Originally posted by mgl
nice work.
Thanks. Well, I guess I can..but I need to twick the CF plate a bit fot the door to fit.
What do you mean? You have to have the key in the ignition for the engine start to work, so its not different than any other Z. If you meant the wiring to the starter, its not thu the firewall. Its ran from another place that its very hard to get to.
Install was alright. Tuning will need some kind of A/F reading. Either from a Dyno, or a wideband readout. Im gonna get the PLX M500 for A/F reading/dataloggin, but til then, Im leaving the SAFC on stock setting. Computer you mean the ECU? Its under the passenger side dash.
Old Apr 11, 2004 | 08:20 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
nice and clean install - not feeling the carbon fiber, but thats just me
that PLX piece is sweet...we will be offering them very soon
Old Apr 12, 2004 | 01:33 PM
CaneZMD's Avatar
CaneZMD
Alright, this is an honest question, How much power can you expect to get from the SAFC2?
I think it looks really cool, but how much power would you get from it with bolt on mods?
I've thought about buying one myself. I have a plenum, intake, UR pulley, cats and a Borla exhaust. Would this be a worthwhile mod or would the $350 be better spent on something else?
Old Apr 12, 2004 | 01:46 PM
Phatmitzu's Avatar
Phatmitzu
Only Dyno will tell. But as for me, I know that I am going FI soon, so Im just getting my parts ready. And it was a pretty good deal that I got on this SAFC II for, so I jumped on it. Buy now, think later.
Old Apr 18, 2004 | 04:58 PM
shimz350z's Avatar
shimz350z
When you install the "engine start button" is there a way where you can wire the button so that when you turn the key...the key itself cannot start the car? Just like the s2k where you are required to press the button. I don't want both.
I have an auto...since you've already accomplished this task I am assuming you may be able to answer my question because I CANT
