Well, Motors Done here's what I think!!!
Old Apr 19, 2004 | 05:44 PM
Blownaway's Avatar
Blownaway
Default Well, Motors Done here's what I think!!!
First and formost, anyone who does any type of internals on the VQ35 should make sure that they bleed the coolant properly this took us about 2 hours, we finally broke down and used a suction devise that Nissan makes to get the air pocket out...after that she stayed on average at 192, I will be installing the Nismo Thermostat later in the week to get it down a little more.A/F showed 102-103% so totally fine.....ok on to the goods..
We used consult to raise idle 250 RPMS this makes the car idle about 900 ish...the car still has a nice lope to it..it doesnt want to stall, but it doesnt sound like a Z anymore, more like something meaner....The car is much louder than before....the headers really opened up the exhaust....
Down low she feels a little slower (I havent sprayed yet)
But around 4600 RPM all hell breaks loose. (like she now has VTEC it pulls hard all the way to red...sounds like a superbike on wide open throttle.
We have now upped the jets to a 150 shot.....and will be dyno ing and tracking the car next week, looking forward to it..
These cams are the most aggressive you can get right now and they are very streetable...very....I think the JWT / Tomie 262 will be a good cam for people to go with that are looking for a little more power in the midrange...
I spoke to Doug at Crawford and he says the car will benefit with a reflashed ECU, but im not sure I want to go with Techno, I would like to hold out for JWT's ECU....
Anywho, I am very happy with the work...I will post the dynos and hopfully run some low 12 second passes on 19s next week, still waiting on drag radials...
anyone have any questions, post em up....
Old Apr 19, 2004 | 07:18 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Woa....backup.
What did you do exactly? Did you just install a cam and headers? I might have missed the previous posts on this...but I am totally lost.
I assume you are trying for low 12's with the NOS?
Old Apr 19, 2004 | 07:33 PM
Blownaway's Avatar
Blownaway
Sorry..Here are the two threads
https://my350z.com/forum/showthread....threadid=69550
https://my350z.com/forum/showthread....threadid=70338
Old Apr 20, 2004 | 05:00 AM
ACP's Avatar
ACP
Default Re: Well, Motors Done here's what I think!!!
Had the same problem when I did the TT install
There is a bleeder valve in the heater hose on the back of the engine.
Couple times opening her up, gets all the air out
Enjoy the new mods
Old Apr 20, 2004 | 08:30 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
there are more aggressive cams for the VQ - Esprit's. I ahve a set here, but still in my decision making phase about using these or the Tomei's (which I also have) but sounds like a good setup overall!
Very curious to see what the dyno shows!
Adam
Old Apr 20, 2004 | 09:08 AM
Chebosto's Avatar
Chebosto
Technosquare's ecu has been proven for over a year now, i'm not sure what difference it will be if you're waiting for JWT's program... Technos has pretty much the entire maps and controls for everything that you're looking for-
Old Apr 23, 2004 | 12:28 PM
redva350z's Avatar
redva350z
bump to see a dyno chart... nice setup man
Old Apr 23, 2004 | 06:16 PM
Sharif@Forged
Forged Performance
2nd bump for a dyno please
Old Apr 23, 2004 | 07:54 PM
Blownaway's Avatar
Blownaway
will be on Sunday...Ill post them before sopranos
Old Apr 23, 2004 | 08:58 PM
webcarconnection's Avatar
webcarconnection
Nice!
What is your baseline to see the improve of the cams and mods?
My last mod was JWT Cams (I believe they have the highest lift avalible rigth now) and the car feel with little less power on lower RPMS but after 4000 it pulls hard
I was talking with Tadashi of Technosquare and he can do the "Limited Spec" for the Z (Rev limiter 7100, Speed limiter and TB Wiresless upgrade) I'm gonna go with that because the peak hp rigth now is on 6450... too high for the 6600 rev limited, the engine can't release all the power
I also put the Consult II to pull up the idle (250 rpms) oh and yes the car sound very different in idle and top end... I like very much
btw I put 280 whp & 270 wtq... look Sig for my mods!
Old Apr 23, 2004 | 09:02 PM
Blownaway's Avatar
Blownaway
247 was my baseline that was with a hotair intake and a cat back exhaust, 14" brakes and 19" wheels, so I guess I am pretty happy with that...I am hoping for around 280 just as yours...are you also spraying your motor?
Old Apr 23, 2004 | 09:19 PM
webcarconnection
Yes I was, before I put the cams... 390 whp & 407 wtq with 125 shot... I have a little accident with the fuel selenoid and two valves broke and melt the six plugs (Iridium) lucky me I know the owner of the dealer and put everything new under warranty, including the cams
rigth now I'm saving up for the TT
Old Apr 24, 2004 | 10:22 AM
Sharif@Forged
Forged Performance
Can I ask why they had to remove your heads to intall the cams? That seems like a lot of labor dollars.
Old Apr 24, 2004 | 10:25 AM
Blownaway's Avatar
Blownaway
Because, I was also installing new valve springs and valve retainers with new headers, the tear down to remove the heads was an extra 3 hours of labor, to install the cams, and then take another 8-10 hours for header install from underneath is upsurd. If you are going to install headers and cams, the way we did it is the most efficient.
Old Apr 24, 2004 | 10:04 PM
Street Visionz, Inc.'s Avatar
Very nice work!!! I never knew JWT made valve springs and retainers for the 350Z, where'd ya get them from? Also what do you mean everything is gasket matched? Sorry i'm such a newbie.
Old Apr 24, 2004 | 11:12 PM
little_rod's Avatar
little_rod
So how aggressive are the cams?? Sounds like a sweet setup, I bet the sound is second to none. I know if I did it, I would want my cams to make my car lope enough to mix chocolate milk(like the commericals of course, lol).
Old Apr 25, 2004 | 02:49 PM
Blownaway's Avatar
Blownaway
the lope is not too bad, you can hear it. SGP racing sells allot of the really sick stuff for the 350Z. you name it they have it...forged pistons, rods, etc....gasket matched means that we matched the opening on the gaskets to the opening on the heads, manifold, etc.....
I dyno'd today. But I am trying to convert the graphs, Ill post them shortly...I definately need a new ECU because the power comes on hard at 6400 and I hit fuel cut at 6600...so I might have to just knuckle up and get the technosquare...
Old Apr 25, 2004 | 04:23 PM
Sharif@Forged
Forged Performance
Gotcha...makes sense now.
Old Apr 25, 2004 | 05:44 PM
12SecZ's Avatar
12SecZ
Word.
Good line.
I feel the same way, I love lopey cams with high flow cats.
The sound it makes says, back off. You don't get so many 6 inch single exhaust kids wanting to race you.
Old Apr 26, 2004 | 09:45 AM
Z1 Performance
Former Sponsor
I am the opposite - the lope is cool on a car with the goods to back it up =- cam lope on a car that will still only muster a 13 second pass is lame IMHO
I'll take the smooth purr of the stock idle thank you - I don't need every modification i do scream "not stock"
Did I read this right - power comes on at 6400?
