V3 Installed
Old May 11, 2004 | 05:57 PM
ChrisMCagle's Avatar
ChrisMCagle
Originally posted by scubasteve
Installed my V3 plenum last night.......the fit was a bit snug, but sits nicely when everything is bolted down. I had a V2 that cracked and was immediately shipped out. So far, so good. The idle is great now. My only concern is the one long bolt by the TB....I think I will just elevate the bolt with washers to get a snug fit.
The bolt should screw down tight. I know that on my V1 I had to drill/ ream the hole a bit with a drill because the hod didn't line up with where it screwed down. Maybe that's your problem too? Once it starts to thread it should continue until it sits flush with the top of the plenum.
-Chris
Old May 11, 2004 | 06:20 PM
CaneZMD's Avatar
CaneZMD
Yeah, that bolt was the hardest one. On the v3 it is countersunk, which helps alot, but on mine, the countersunk area was a little off, so that when the bolt got tight, the lip of the countersunk area pushed the socket off of the bolt. I just gently pushed back, and it worked fine.
Old May 11, 2004 | 07:25 PM
NISMO_GUY2003's Avatar
NISMO_GUY2003
I also recently installed v.3 of the Kinetix. Anyone have any cracking problems yet? I think I saw where one forum member had a crack by the throttle body, but it seemed like an isolated case?
So far so good with v.3!
Old May 11, 2004 | 07:43 PM
all_bark's Avatar
all_bark
Am I the only one still going strong on the Version ONE plenum?
It seems everyone jumped right over from one to three or from two to three!
I am sure that eventually I will move *UP* to the version three but at the moment i have no problems so my moto is,
If it aint giving you any problems, leave it the **** alone!!!!!
btw - Chris, how the hell are you?
Old May 11, 2004 | 08:28 PM
ChrisMCagle
Talking 'Sup
Hey Joe! Long time no see. I'm doing pretty good, how about you? Glad to hear that your V1 is still going strong. I'm still running my V2 with no issues so far.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
