AEBS Stroker Kit 11.5 : 1 / 101.5mm, engine size 4269.35cc
Old May 25, 2004 | 07:26 AM
newtkindred's Avatar
newtkindred
Default AEBS Stroker Kit 11.5 : 1 / 101.5mm, engine size 4269.35cc
http://www.aebsracing.com/products.p...ct=vq35stroker
Anyone know about this stroker kit?
Kit contents:
T-Sleeves
Patented three-dimensional support design eliminates sleev movement under extreme dynamic load
Solid deck T - Sleeve technology provides greater head gasket surface sealant area
Additional piston skirt support for new stroke
Connecting Rods
Pauter E.D.M drilled for wrist pin lubrication and piston cooling utilizing under-the-piston oil spray
Pistons (3 types available)
Turbo 8.5 : 1 / 100mm, engine size 4231.16cc
N/A 11.0 : 1 / 101.5mm, engine size 4269.35cc
N/A 11.5 : 1 / 101.5mm, engine size 4269.35cc
Includes chrome steel rings, wrist pins and clips
Head gasket
Custom cut Cometic head gasket
Crankshaft
Material: 9325 (custom billet steel, same material used in Top Fuel NHRA engines)
Stroke: 90mm (stock is 81mm)
Old May 25, 2004 | 07:43 AM
PoWeRtRiP's Avatar
PoWeRtRiP
omg plz search on that its been beat to death
Old May 25, 2004 | 08:19 PM
Nathan's Avatar
Nathan
AEBS have miscalculated the capacity of there stroker kit
The 101.5mm bore with a 91mm stroke has a cap of 4417cc & with the 100mm bore it will be 4288cc
Keep the stock 81.4mm crankshaft with a 101.5mm bore the cap
will be 3951cc
Old May 25, 2004 | 08:25 PM
Nathan's Avatar
Nathan
MY MISTAKE
I thought the stroke was 91mm but its 90
Old May 25, 2004 | 08:40 PM
Nathan's Avatar
Nathan
Redone the calculations
With a 101.5mm bore & a 90mm stroke the capacity is 4369cc
liqalu04
Jan 2, 2022 12:58 PM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
