A got to have item...
Old Jun 11, 2004 | 11:50 AM
Yuichi's Avatar
Yuichi
Talking
Yah this is a great tool that we used for the SportZMagazine Dyno shootout a long time ago.
Made sure everything was consistent and its easy plug and play
Old Jun 14, 2004 | 09:51 PM
DaveO's Avatar
DaveO
Alagolfer and I spent part of today insulating the back of his Popcharger's velocity ring (picture above) and comparing the temperature profiles of his insulated JWT Popcharger and Z-tube vs. my insulated Stillen CAI system and Z-tube.
Please note: We don't present this info as absolute. These are the numbers we got while driving both cars throughout the day.
Alagolfer's 03.5 G35 Sedan
Air Intake System: Popcharger w/heat shield & Z-tube - Back of the velocity ring, MAS Air Flow sensor and Z-tube are fully insulated.
Ambient Temp (dash readout): 97F
A/C System: On
Radiator Fans: On or Cycling.
Water (Coolant) Temp: 190F - 210F
Intake Air Temp @ Idle for 5 minutes: 134-138F
Intake Air Temp @ 60mph: 116F
Approximate Cool Down Time: 2+ Minutes
Note: Pre-insulating the V-ring numbers - 82F air temp & 114F idle temp.
DaveO's 03 G35 Sedan
Air Intake System: Stillen CAI w/Popcharger air filter & Z-tube - System, including MAS Air Flow sensor, is fully insulated.
Ambient Temp (dash readout): 98F
A/C System: On
Intake Air Temp @ Idle for 2+ minutes: 112-115F
Intake Air Temp @ 60mph: 107-109F
Alagolfer noted throughout the day his temps were about double what mine were. For example: At idle, when the Stillen system was about 15F above ambient temp, the Popcharger’s temps were 30-35F above ambient. At 60mph the insulated Popcharger system was an average of 10F higher than the insulated Stillen system.
Next up... the stock air case with an insulated Z-Tube.
We'd still like to get info on a non-insulated Popcharger - Z tube, a K&N Short Ram, and an Injen, AEM, or Nismo system. FYI, the pavement temperature in front of the house was 155F with a 90F air temp. We didn't get it at 98F.
DaveO & Alagolfer
Old Jun 15, 2004 | 04:55 AM
jjellyneck's Avatar
jjellyneck
Great info. The temp differences will generate a noticeable difference in power.
I need to look at my stock intake setup (with Z tube) to see about simple mods to the stock intake enclosure and the grill area that'll allow for more effective intake from up high (not down near the road).
Old Jun 15, 2004 | 05:25 AM
DaveO's Avatar
DaveO
Jeff,
We can sure use more independent "real world" information for G and Z owners.
DaveO
Old Jun 15, 2004 | 05:44 AM
jjellyneck's Avatar
jjellyneck
Originally posted by DaveO
Jeff,
DaveO
I might look into one of those trick little units that you're using. I had a software with cable setup for my previous Audi S4 that worked pretty well. It hooked into my laptop. The turbo engines are a little more finicky, so it was money well spent.
Old Jun 15, 2004 | 06:58 AM
12SecZ's Avatar
12SecZ
too bad it didn't show A/F I would buy one in a second!
Max (Technosquare tuned to 9 PSI)
Old Jun 15, 2004 | 07:08 AM
PoWeRtRiP's Avatar
PoWeRtRiP
it might register karman values, i know that a consult scanner can record a/f through the karman sensor in you exhaust.
Old Jun 15, 2004 | 07:12 AM
12SecZ's Avatar
12SecZ
That would be awesome, we have come a long way.
Old Jun 15, 2004 | 07:41 AM
ColecatZ's Avatar
ColecatZ
We used the Techtom MDM-100 on the 300zx TT and they were great. Not so much for tuning but monitoring and troubleshooting. If Idle started acting up or perfomrance changed you could usually track the issue down easier with one.
They were about $400 then.......nice to see they came down. Been looking for one.
Thanks for posting.
Joshua
Cass007
Intake
May 23, 2011 08:18 AM
drivessidewayz
Exterior
Apr 10, 2011 10:55 AM
Colonel Sanders
Nov 19, 2010 07:20 AM
