**DYNO RESULTS: Start your -itchin
Old Jun 18, 2004 | 11:58 AM
ares's Avatar
ares
Veteran
I think its just automatic playing tricks on you. torque converter doing its job, all the way though the rpm(though it shouldnt) thus increasing torque; and to the dyno, increasing HP.
Old Jun 18, 2004 | 01:24 PM
maserom's Avatar
maserom
Sweet, I knew someone would complain that this dyno is higher than theirs. I agree with Ares, the guys at the shop warned me that the TQ may screw with the numbers slightly.
Old Jun 18, 2004 | 01:49 PM
booger's Avatar
booger
Well if your refering to me....wasnt...didnt complain...That fact of the matter is.... that your dyno looks nothing like any other basic stock Z or G AT5 or 6MT .Granted the pulley should give you a few hp .But there is no getting around the timing in the ECU...unless you have a flash or piggy back ECU .If you look at your base dyno...you will see the dips in hp at the same spots as every G or Z .So I can come to only 3 reasons why it looks the way it does....[1] It isnt a G or Z dyno [2] you have a piggyback or a reflash and arent owning up to it [3] the dyno is screwed up and giving very false readings
Old Jun 18, 2004 | 06:14 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
there is only one way to find out! take it to the drag strip! with 265whp, the car should easily be in the 13's... maybe mid 13's...
I don't think it's bs, like ares said, it may be the torque converter playing trick on the dyno
Old Jun 18, 2004 | 08:53 PM
ajk4's Avatar
ajk4
yea, there is no way to raise the rev limiter and from the dyno's i've seen the car tends to run rich at higher rpms with a stock ecu. it's kinda hard to tell exactly where the redline is with the way the rpms read across the bottom, but it is making power all the way to the redline (which is something i've never seen). however, the stock ecu can do different things at different times and as we all know tends to adjust to your driving habits, etc., but still this is kinda funky with a stock ecu. i dyno'd a baseline of 225hp and 250hp with all my mods so i pretty envious of your numbers.
Old Jun 18, 2004 | 09:33 PM
350ed's Avatar
350ed
Professional
ajk4, whatcha talking about? You have a TS ECU and it raises the rev limiter!???
Old Jun 18, 2004 | 10:00 PM
ajk4's Avatar
ajk4
i meant with the stock ecu.
Old Jun 18, 2004 | 10:10 PM
adanande's Avatar
adanande
get an exedy fluwheel and replace you stock crank pulley your car wont last another three years with that pulley on the crank. Please don't scare me with posting crank pulley that mod is extreemly harmfull how can poepl even sell it?
Old Jun 18, 2004 | 11:09 PM
Street Visionz, Inc.'s Avatar
Default Re: dyno
hehe yeah I was surprised my graph didnt have any dips either..making power all the way to redline. Also I was running extremely lean so I dunno what that does to the timing and all. Maybe the ecu is pulling a lil timing or something on mines. Anyways I'll post the chart up as soon as I figure out how to get it onto the comp.
Originally posted by booger
Sorry..but Im starting to think this is NOT a dyno chart from a Z or a G . The stock ECU adjusts timing at 5,400 rpm's...and you see a dip in power on every chart I have seen .Then again at 6,400 rpm's you see a big drop off in power . I think Nissan does this at 6,400 rpm's to stop engine damage if you hit the fuel cut off .So I call BS on this chart
Old Jun 18, 2004 | 11:23 PM
shortcut3d's Avatar
shortcut3d
I believe that the DC headers could be scavenging the cylinders really well. This would keep the power from dropping off at high RPMs, similar to the plenum. Good cylinder scavenging created by tuned exhaust system can suck new air-fuel mixture into the chamber. The front angle of the stock plenum may complement the headers by increasing velocity.
Of course I don't know what I'm talking about. Just theory.
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
Dymsi
Sep 29, 2015 11:32 AM
