add octan booster in your gas tank?
Old Jun 22, 2004 | 06:15 PM
kws's Avatar
kws
Default add octan booster in your gas tank?
just had 91 octan gas in canada
would u guys is fill in a octan booster in your each one gas tank?
because z350 engina is high performance engina.
i want to know if i add it in my each gas tank, will it hurt my engina.
thanks answer my question
Old Jun 22, 2004 | 06:50 PM
UsafaRice's Avatar
UsafaRice
Default Re: add octan booster in your gas tank?
The US Z is designed to run with 91 octane fuel. Adding an octane booster should not be required.
If you are adding a booster, something like toluene would be better than an alcohol for the sake of fuel line life.
Old Jun 22, 2004 | 10:05 PM
shortcut3d's Avatar
shortcut3d
Octane booster do not really raise the level enough to make a difference. Plus you would have to burn about one whole tank before the ECU fully adjusted. Off the shelf octane boosters are good for fuel system cleaning. When you buy it make sure it is cat safe and meets the standard for merc or bmw lube properties and cleaning. Most will note those standards.
Toluene really does work. Again, it is not needed.
Old Jun 23, 2004 | 05:08 AM
jjellyneck's Avatar
jjellyneck
Octane booster or toluene/toluol is good to add to the tank in that rare ocassion when you are out of gas and can only get low octane.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
