fuel system pressure release
Old Jun 30, 2004 | 10:42 AM
PhiTauZ's Avatar
PhiTauZ
Question fuel system pressure release
can somebody help me out and tell me which fuse needs to be pulled in order to depressurize the fuel system?
Old Jun 30, 2004 | 11:59 AM
narkotic's Avatar
narkotic
Well, I have a G35, so i'ts a differnet fuse, however, i'ts easy to find. Behind your battery there is a main fuse box (total of 3 in the car I believe), you have to slide the huge cover over it and there is a diagram on which fuse is what. With the car running, pull the fuse is what I do, wait for it to die. Then i unscrew the fuel regulator and dont pull it out yet, i let the pressure sort of die down. After about 15 mins I wrap towles around it and pull out, fuel will spurt eveyrwhere still depending on how long its been since you drove the car. I did mine right after i was driving from work and it squirted all over my damn face... heh. fun stuff
Old Jun 30, 2004 | 01:50 PM
teh215's Avatar
teh215
I forgot to bleed the fuel pressure when I installed my Vortech kit using the fuse method but, when I did separate the coupling on the frame rail after the car was setting for about 1.5 days I got very little fuel spilling. I was certain I was going to take a bath in gas ...
Like narkotic said, I believe it is labeled on the fuse block cover.
Old Jun 30, 2004 | 06:48 PM
ZDreamZ's Avatar
ZDreamZ
Why would one need to do this ?
Old Jun 30, 2004 | 07:26 PM
DaveO's Avatar
DaveO
Default Re: fuel system pressure release
The fuel pump relay fuse can be found in the IPDM E/R (Intelligent Power Distribution Module - Engine Room).
The IPDM E/R is the large black box located just behind and a little to the right of the battery.
The fuse you want is labeled #81. It's the lowest (red) fuse in the left hand or outboard row of fuses.
DaveO
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
