Best Flywheel
Old Jul 22, 2004 | 04:48 AM
tommy81569's Avatar
tommy81569
I was contacted by Courtesy and they informed me the JWT Lightened Aluminum Flywheel was on back order, so it doesn't look like I will be installing it anytime soon. My mechanic suggested I not install it to begin with. He said that the steel on the sides of the flywheel has been known to separate over time. Anyone noted any problems with this?
Old Jul 22, 2004 | 05:19 AM
stx's Avatar
stx
Originally posted by Z BOY
Cost of Jun flywheel? Do you need to replace clutch?
I paid $420 shipped from SGPRacing and I didn't need to replace the clutch.
sorry about interupting the thread but i am getting the JUN soon and want to know an average install price. I did a search but cant find any $$$.thanks.
I would guess around $500 dollars.
I don't know how true this is but I have heard of people that has happened to but on aluminum flywheels only. The JUN is a one piece chromoly steel flywheel and will not seperate.
Old Jul 22, 2004 | 08:00 AM
redline350ZZ's Avatar
redline350ZZ
Im getting the tilton setup installed....
7 hour install........$85/hour
$595...
tax and all comes out to 647.00...including rasing the idle and installation of the pedal stop
Old Jul 22, 2004 | 09:12 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
they are charging you tax on the labor?
we dont have to do that in california... guess some other state law's are different...
let me know if ou have questiones setting the pedal stop!
Old Jul 22, 2004 | 09:48 AM
Jason@Performance
Performance Nissan
here is a pic of the pedal stop installed...
Old Jul 22, 2004 | 09:49 AM
Jason@Performance
Performance Nissan
here it is with the clutch pressed in hitting it... see how far it is from the sensor that will let you start the car...
Old Jul 22, 2004 | 09:50 AM
Jason@Performance
Performance Nissan
we disable the switch that you have to hit to start the car...
i can start my car without pressing the clutch...
just make sure you are not in gear!!!!!!!!!!!!
Old Jul 22, 2004 | 10:25 AM
ChrisMCagle's Avatar
ChrisMCagle
Jason,
What exactly is the purpose of the stop? And why would you want to disable the sensor?
-Chris
Old Jul 22, 2004 | 11:31 AM
redline350ZZ
I already have the sensor disabled...I can start my car without the clutch also.....its for my auto-start...with my alarm....
Old Jul 22, 2004 | 11:36 AM
Jason@Performance
Performance Nissan
Originally posted by ChrisMCagle
Jason,
-Chris
if the pedal stop was not there the the clutch pedal would go all the way to the floor and it would wear out the pressure plate and burn up the clutch...
after the pedal stop is installed the pedal wont go down far enough to hit the sensor so the car wont start when you press down the clutch...
i think this is the "problem" with the trans in our car... when you press the clutch all the way to the floor it is hard to shift into gear... but when you press the clutch half way down it goes into gear easly...
Old Jul 22, 2004 | 11:39 AM
Jason@Performance
Performance Nissan
good, one less thing for them to worry about...
its a liabliity thing we have to let people know about other wize we dont want to get sued for people starting their cars in gear and it shooting forward...
ever start the z in gear with the e-brake down pressing the sensor... you shoot forward...
Old Jul 22, 2004 | 12:23 PM
goldndwgz's Avatar
goldndwgz
Before buying the JUN do your research...because this thing is one piece and so thin theres no where for the heat to escape. Therefore this one is more likely to crack over time....I would stick with the JWT(Fidanza) or RPS
Old Jul 22, 2004 | 12:39 PM
ChrisMCagle
Thanks for the info. There's no need to unhook the sensor with the stock clutch/flywheel, is there? Also, does it throw a SES light?
-CHris
Old Jul 22, 2004 | 01:18 PM
Jason@Performance
Performance Nissan
no need because you can press the clutch pedal all the way to the floor to start the car with the stock set up...
although... i do not think you should press the clutch all the way to the floor with the stock set up... i think that is what is starting all the tranny problems...
Old Jul 22, 2004 | 01:23 PM
stx's Avatar
stx
The JUN is a forged flywheel made from Chrome Molybdenum which makes it much alot more heat resistant than standard steel. I also don't know of anyone that has had trouble with the JUN flywheel with other Nissan engines. If you do please let us know what type of car and what was the problem.
Old Jul 22, 2004 | 01:48 PM
redline350ZZ
I did start my car by accident (auto-start) with the car in gear once....I was parked in a drive-way with a slight incline.....anyway the car shot forward and put a huge dent in the beer fridge..... and now I have a NISMO body kit......the parking brake is not strong at all...LOL.... oh well.....The car shot forward so hard though that it crushed my injen CAI filter.... thats a lot of force....
Old Jul 22, 2004 | 02:19 PM
dnguyent's Avatar
dnguyent
In the past 16 years, I only depressed the clutch half-way to change gears, except when putting it into 1st gear; then I depress all the way. Then, I had the tranny in the Z replaced; read the manual more carefully, and found that it recommended full depression of the clutch pedal. So, now, I depress it all the way. It was hard getting over that habit.
Old Jul 22, 2004 | 02:32 PM
  #38
Jason@Performance
Performance Nissan
I dunno...
you can lift up the clutch pedal quite a bit before it starts to engage...
Old Jul 22, 2004 | 02:44 PM
  #39
G3po's Avatar
G3po
Default clutch stop
Jason, do you sell the clutch stop independently from the Tilton clutch. It also appears that with a few washers etc, that the switch contact poitn could be "raised" to allow the switch to be depressed even with the stop is installed.
Old Jul 22, 2004 | 04:42 PM
  #40
Jason@Performance
Performance Nissan
yes I do sell them seperatly... it is something we fabricate and each one needs slight modification (bending) depending on the car...
there is some adjustablity in the sensor... but, I prefer not having to step on the clutch
