Best Flywheel
Old Jul 22, 2004 | 09:05 PM
  #41
Carlitos's Avatar
Carlitos
JWT fly/cth combo here with many Dyno pulls of over 400whp and 12sec 1/4 passes and no signs of problems yet. I think is very cost effective.
Old Jul 23, 2004 | 04:30 PM
  #42
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
ok...
I will anounce it on Monday officially...
but...
the best streetable flywheel / clutch solution is finally here...
official post on monday...
Old Jul 23, 2004 | 04:34 PM
  #43
NismoKid's Avatar
NismoKid
Originally posted by Jason@Performance
ok...
but...
Is the Tilton setup finally going to have a very streetable clutch?!?!
Old Jul 23, 2004 | 04:35 PM
  #44
G3po's Avatar
G3po
Default Announcement
a carbon/carbon clutch and lightweight fly for under $1500 would definately get my vote.
Old Jul 23, 2004 | 09:52 PM
  #45
uro279's Avatar
uro279
JWT / NISMO / JUN / STILLEN will all use the factory clutch OR NISMO or JWT clutch... and the NISMO / JWT Clutch will bolt up to any of the above flywheels...
the TILTON requires a different clutch due to the fact it only has a 7.25" surface area...
best streetable combo (for now, :P ) is the JWT Flywheel and NISMO Clutch
best semi streetable is the TILTON set up listed above... and this set up will handle over 900HP to the wheels...
Why is the JWT flywheel with Nismo clutch a better set-up that using the JWT clutch?
Old Jul 24, 2004 | 12:03 AM
  #46
Jason@Performance
Performance Nissan
NISMO clutch weights a couple pounds less than the JWT... over all lighter weight...
remember the clutch bolts to the flywheel...
Old Jul 26, 2004 | 05:06 AM
  #47
redline350ZZ's Avatar
redline350ZZ
I just ordered and received my Titlon setup last week and now there is a better setup????? that sucks...... well I wanna install but am hesitant now.....whats up Jason???
Old Jul 26, 2004 | 05:24 AM
  #48
UsafaRice's Avatar
UsafaRice
no need because you can press the clutch pedal all the way to the floor to start the car with the stock set up...
although... i do not think you should press the clutch all the way to the floor with the stock set up... i think that is what is starting all the tranny problems...
Jason, this is interesting. Is this a personal idea, or something you have heard from somewhere else? If it's really the case, I'm sure I would modify the pedal travel or my shifting.
Old Jul 26, 2004 | 07:48 AM
  #49
Jason@Performance
Performance Nissan
If you are planing on making over 300RWHP the set up you have is for you...
Old Jul 26, 2004 | 08:02 AM
  #50
Jason@Performance
Performance Nissan
personal idea...
I also remember driving my car with the stock clutch and it would be hard to jam into gear and then when i lifted up the clutch a little it was easy to get into gear...
Old Jul 26, 2004 | 09:15 AM
  #51
Balls's Avatar
Balls
how is it that pressing the clutch pedal down fully can affect shifting in any way?
if shifting were easier with the pedal half pressed, I would think that you're just helping the synchros... (same theory behind double clutching)
Old Jul 26, 2004 | 09:19 AM
  #52
Jason@Performance
Performance Nissan
well, if you press in the clutch too far, it will re-engage the clutch...
Old Jul 26, 2004 | 09:28 AM
  #53
ChrisMCagle's Avatar
ChrisMCagle
Default It's Monday
ok...
but...
Well.... what's the verdict, Jason? What is the best streetable flywheel / clutch combo?
-Chris
Old Jul 26, 2004 | 10:01 AM
  #54
Balls's Avatar
Balls
I've never heard of that before? Are you sure? I'm not trying to be argumentative here... I just want to know. Can you explain how this is possible?
Old Jul 26, 2004 | 10:27 AM
  #55
Balls's Avatar
Balls
ok... if you're losing pressure at max depression... I could see that happening... but that's the only way i can see that being possible... and if that were the case... I'd call it broken.
Old Jul 26, 2004 | 11:34 AM
  #56
eazy's Avatar
eazy
I second that.
Old Jul 26, 2004 | 03:06 PM
  #57
azaz's Avatar
azaz
Originally posted by eazy
I second that.
3RD!!!
Old Jul 26, 2004 | 06:07 PM
  #58
redline350ZZ
Tilton Flywheel getting installed right now......
Cant wait to drive it tomorrow.......hope all goes well
I am prepared to stall out.....
Old Jul 26, 2004 | 07:15 PM
  #59
Z BOY's Avatar
Z BOY
Default Stupid question
So how far down does the stock setup need to be pressed in order to start or shift?
Old Jul 26, 2004 | 07:34 PM
  #60
Jason@Performance
Performance Nissan
sit in an empty parking lot... nothing infront of you...
press the pedal to the ground in first gear... slowly lift... you will find the point where it starts to grab, and you only need to press down about 1/4" past the point where it starts to grab...
this is just MY OPINION... you dont need to go by it, but try it out...
check out this thread
https://my350z.com/forum/showthread....threadid=85005
