jwt oil spacer HELP !!
Old Jul 28, 2004 | 03:28 PM
redls1's Avatar
redls1
Default jwt oil spacer HELP !!
I installed the oil pan spacer but kinda stripped one of the bolts. I got it back on but obviously by the oil underneath my car not enough. What to do ?
Old Jul 28, 2004 | 03:42 PM
Enron Exec's Avatar
Enron Exec
Get a new bolt...
redls1's Avatar
redls1
well I jacked the car up and its not as bad as I thought. The gasket I used was thick enough or didnt have enough time to dry and its leaking in the corner of the pan. Worst case is I have to drop the pan again and redo. Is there anything as a temp fix I can use to stop the oil from leaking? I just goobed so gasket sealer on there for now hoping for the best. Its getting ready to storm and I dont have access to the garage.
Old Jul 28, 2004 | 03:44 PM
redls1's Avatar
redls1
AHH let me rephrase that also. The bolt isnt stripped the hole is. longer bolt?
Old Jul 28, 2004 | 03:58 PM
raidersfan's Avatar
raidersfan
you will need to retap the hole. no big deal really just go slow and be careful.
Old Jul 28, 2004 | 04:04 PM
redls1's Avatar
redls1
so far so good, now i just need to explain to the father in law the big oil spot in the drive way.
apex locator
Jul 23, 2021 02:27 AM
