Kaaz Lsd
Old Aug 5, 2004 | 08:13 PM
weslutes's Avatar
weslutes
Default Kaaz Lsd
I had the KAAZ LSD installed and thought I'd share my impressions.It is still breaking in so it is pretty loud on corners when its cold.after its warm,it is quiet.This should have been one of my first mods. Its awsome.noticably grippier(if thats a word).The LSD along with the Stillen valve body made my tires stick to the ground and quickened my 0-100 times.My butt dyno was surprized.
Old Aug 5, 2004 | 08:21 PM
apex locator's Avatar
apex locator
congrats. i had one installed a few weeks ago, set at 60%
havent had a chance to hit the track yet to really test it out, but driving the car is def. a different experience.
the rear end is more sketchy now, so be careful
Old Aug 5, 2004 | 08:31 PM
350z4steve's Avatar
350z4steve
get use to drifting more
Old Aug 5, 2004 | 09:17 PM
weslutes's Avatar
weslutes
Yep, 60%
Sketchy?You guys aren't kidding,this thing wants to drift at 10 mph!
Its awsome!
Old Aug 5, 2004 | 09:45 PM
axxizzer's Avatar
axxizzer
how do you like that valve body?
Old Aug 6, 2004 | 07:15 AM
ACEMAN's Avatar
ACEMAN
Master
Question for you guys with the KAAZ
What was the main reason you picked this one over the nismo version? Arnt they pretty close in price?
Im looking to replace mine being that i have a base model. So what are your opinions on the pros and cons of the two?
Thanks
Laterz
Aceman
Old Aug 6, 2004 | 05:40 PM
PhoenixINX's Avatar
PhoenixINX
At 10mph it's locking up THAT badly????
Why do you guys think thats a good thing? YIKES!
Old Aug 6, 2004 | 06:54 PM
weslutes's Avatar
weslutes
I chose KAAZ because they are 4 streets down from me and Ray seemed like a cool guy.I've only heard good stories from customers.
O.K. I guess I exagerated a bit.
I can hear the tires gripping.So I assotiated that with drifting.
Coming out of a turn is where you notice the difference.It keeps you on the ground & it actually prevents you from drifting when your coming out of the turn,which results in better traction and quicker acceleration.
Now going into a turn is the tricky lesson
Old Aug 6, 2004 | 06:59 PM
PhoenixINX's Avatar
PhoenixINX
Okay, so I understand the leaving a corner... which it's doing what it should be.
However, why is it tougher entering a turn?
Old Aug 6, 2004 | 09:43 PM
weslutes's Avatar
weslutes
Well, the lsd makes the wheels spin at the same speed(almost).when you turn,your inner wheel spins faster.When the outside wheel cant spin fast enough,the wheel chirps.
Since your outer wheel is already breaking loose,it's much easier to loose controll on your inner wheel.So every time you enter a turn, you're on the verge of chirping the outer wheel then braking the inner wheel loose(drifting)
By the time you're coming out of the turn,it's straitening itself out & will be more predictable sincethe same amount of power is going to each wheel.
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
