UR Crank Pulley...Warranty Safe?
Old Aug 6, 2004 | 07:22 AM
mlemieux137's Avatar
mlemieux137
Default UR Crank Pulley...Warranty Safe?
just a quickie before i buy....if its installed buy someone that specializes in Z's (Palm Nissan, FL, has thier own perforamance shop)...will the crank/pulley be reliable i.e. not break? and second how will it affect my warranty? if i get the pulley in black can i fool someone by the naked eye and say 'I dont have pullies'?
Old Aug 6, 2004 | 12:33 PM
murrman100's Avatar
murrman100
Default Re: UR Crank Pulley...Warranty Safe?
They shouldn't affect your warranty at all. Check with your local Nissan dealership just to be sure. Or better yet, have your local Nissan dealership install it.
I had my pulleys installed by Performance Nissan and they said it wouldn't affect my warranty
Old Aug 6, 2004 | 10:42 PM
350Zteve's Avatar
350Zteve
There is a VERY HIGH chance that the dealer will void your warranty on the engine if you run this pulley. Not all dealers are the same, but most would happily void your warranty on the engine if they see the pulley.
Old Aug 6, 2004 | 10:44 PM
mlemieux137
what if i got them installed at the dealer?
Old Aug 6, 2004 | 10:52 PM
murrman100's Avatar
murrman100
Hello!!
Old Aug 8, 2004 | 07:20 AM
toothlessracer's Avatar
toothlessracer
Murrman,
Can you tell the difference on your pulleys? I've though about getting either intake or pulleys most people say go with the pulleys since the intake wont add much power other than the whistle.
I live in West Covina about 5 minute drive from performance nissan. also what did you pay forthe pulleys?
Old Aug 8, 2004 | 07:26 AM
Steel Heals's Avatar
Steel Heals
Regarding the warranty issue, remember Magnusson vs. Moss.
Old Aug 8, 2004 | 08:25 AM
murrman100's Avatar
murrman100
Originally posted by toothlessracer
Murrman,
They don't add that much power, but they do a bit of low end punch. Probably about 5-6 hp. They look very nice next to my Injen CAI.
I looked around a lot. Ebay had them for $340 and Perfomance Nissan had them $325. I had to pay tax but I least I didn't have to wait for shipping.
Old Aug 8, 2004 | 09:38 AM
zectasy's Avatar
zectasy
if anything happens and your local dealer talks **** just tow it to performance nissan...its what i would do lol
Old Aug 8, 2004 | 09:48 AM
mlemieux137
i dont know anything about this. what are u talking about?
you dont need to get the three piece set only the one pulley right?
Old Aug 8, 2004 | 10:11 AM
murrman100's Avatar
murrman100
Yes. The crank pulley is the one you need, but having all 3 looks great.
Old Aug 8, 2004 | 10:14 AM
mlemieux137
thanks.....so if for instance "a person has never seen the Z engine bay. and you get the black crank with the black pulllies, could that person tell that the pullies wernt stock?"
Old Aug 8, 2004 | 10:20 AM
murrman100's Avatar
murrman100
[B]thanks.....so if for instance "a person has never seen the Z engine bay. and you get the black crank with the black pulllies, could that person tell that the pullies wernt stock?" [B]
I don't think so. Unless that person knew a lot about pulleys or engines.
Old Aug 8, 2004 | 10:29 AM
mlemieux137
awesome...so from what ive heard..the pulley is worth 5-6 hp...its been proven by independent dynos?....the engine will rev up a little quicker?....and if its installed properly there are no problems?
Old Aug 8, 2004 | 11:16 AM
murrman100's Avatar
murrman100
The engine will rev quicker and smoother.
No problems, except that you'll want to drive your Z more and faster than before.
Old Aug 8, 2004 | 11:49 AM
hungster's Avatar
hungster
there can be problems with aftermarket pullies, especially since they usually are never balanced with your motor, and they dont have any harmonic balancers in them. You can have crank failure or problems later down the line.
Old Aug 8, 2004 | 12:02 PM
murrman100's Avatar
murrman100
Jeff and Jason at Perfomance Nissan highly recommended these UR pulleys and they said that the Z's engine is internally balanced.
They even said that it could lengthen the life of the engine because of the lighter weight of the pulleys.
Old Aug 8, 2004 | 12:04 PM
hungster's Avatar
hungster
but does it have a harmonic balancer?? an engine can give off noise that can cause vibrations, its not something we can hear, but you can get the effect of it. It can cause alot of premature wear because of the vibrations. It can also cause crank failure over time.
Old Aug 8, 2004 | 12:09 PM
murrman100's Avatar
murrman100
I'm not a pro when it comes to harmonic balancers. We should ask Jeff or Jason about that stuff. They are the pros and with what I've seen on their cars, they should know.
I'm suprised that they haven't responded to this thread by now.
Hold on a sec. It Sunday and they are probably out crusin in their Z's right now.
Old Aug 8, 2004 | 12:48 PM
toothlessracer
thanks for the info Murrman.
do you happen to know who owns that burnt orange Z I always see parked @ performance nissan?
