Lets see you figure this one out!
Old Aug 8, 2004 | 07:03 AM
2003z's Avatar
2003z
Originally posted by bascelik
2003z, out of curiosity, what was your best dyno with stage 3? I'm estimating stage 2 at about 300-305whp/285-290wtq, and stage 3 at about 325-330 whp/300-305wtq. Are these good estimates?
I dyno'd 320/305 with the hollow cats and a 13-14:1 af ratio. I put the stock cats in and have a wideband, and my a/f is in the low 12:1 now, plus the car feels stronger, but I haven't redynod. I would guess 340/320 since thats what the sportz test got on 91 octane, and I have 93. I'm done wasting my money on dynos though.
Old Aug 8, 2004 | 07:05 AM
2003z's Avatar
2003z
Default Re: Lets see you figure this one out!
What's even funnier, according to SGP guys, I'm running mostly about 5psi of boost, at best 5.5psi. This is a 6psi pulley. Again, WTF!?
If they measured the boost, than a good bet is the high-flow cats. Stillen told me this engine with too little restriction and valve overlap (or something like that), allows the boost to escape and it puts less fuel in accordingly. With hollow cats or headers, the stage 3 will only sense 6lbs instead of 7. However, they did say hi-flow cats should be ok, so what do I know?
Old Aug 8, 2004 | 08:55 AM
PhoenixINX's Avatar
PhoenixINX
Originally posted by was wesman
Sure...heat causing losses of 60-80hp ? Don't think so... there is another issue somewhere. I could see heat causing losses like that ona 800rwhp car, but not one that only puts out 235rwhp to begin with.
I've got probably 100 dyno sheets sitting in front of me for cars of mine that I've dynoed at various times of the year, mind you these are all FI'd cars (Lightning,300zxTT, 350Z) and they have seen differences in temps, but nothing compared to what he's describing.
--wes
You're exactly right. It's not the heat...
It's the timing, which is directly related to heat. All aluminum engines, and in this case an FI one are going to get ultra hot. Granted these engines don't seem to mind the heat as much as I've seen other all aluminum, but point being that car is pulling timing.
... and yes, it could lose a GOB of power if too much is pulled.
Old Aug 9, 2004 | 05:40 AM
bascelik's Avatar
bascelik
I drove today at 6am to work, at only 84F (yup, that's Houston for ya) and there is a noticable improvement in pull and HP. However, it is not more than 15-20whp, according to my butt-dyno. I'm pretty sure car is losing power somewhere else as well... this week, I'm calling around for a shop to run a check-up.
Old Aug 9, 2004 | 06:21 AM
bwzabodyn's Avatar
bwzabodyn
lightspeed auto, turbochargers.com
I'd give one of them a call and see if they could help you out... but that's kinda weird since I've heard nothing but good things about SGP... was it the first time they installed a Stillen?
Old Aug 9, 2004 | 04:19 PM
bascelik's Avatar
bascelik
I cannot speak for sure, but I think so. They work predominantly with turbos. However, FI is FI....
Old Aug 9, 2004 | 04:25 PM
Moroccan_Mole's Avatar
Moroccan_Mole
maybe try autologic
lapham3
Oct 7, 2022 03:15 PM
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Depravity
Oct 1, 2015 04:49 PM
