At what RPM do you idle?
Originally posted by ragtopz
that first line is the 500 rpm marker. that makes a lot more sense.
the first long line after the zero is 500, then it goes in increments of 100 rpms.
So my car idle at 650... oops... sorry for confusion...
I guess I fell into that trap as well. I thought each increment was 200 rpm, but if that first tick is 500 rpm, then my idle would also be around 650 as well. I guess now...why would my car at "warm" startup wants to "die"?? It's that same ideal where people where putting it in neutral and all of a sudden the tach would go all the way down to zero, and the car would die. I'm almost tempted to put the stock air box back on to see if the popcharger is the culprit. Any clues??
BUMP!
ok the pic below
i took this picture when i bought my new z
idle looks normal
but after 2 years of driving..
my idle sit arounds 300~400 rpm?
the red line i drew is where my idle is. ( nothing to do with X mark)
i have cleaned TB, cleaned MAF, checked vac leak( no leak)
when i turn my AC idle jumps to 950rpm sometimes 900rpm
could it be the Alternator? spark plug?
my 2008 z is bone stock, 36k miles
changed new clutch and flywheel under warrenty ( i can still hear chattering.. i thought they swapped my bearing but no?)
btw my z jerks while deceleration in 1st and 2nd gear
sometimes 3rd.
ok the pic below
idle looks normal
sometimes 3rd.
BUMP!
ok the pic below
idle looks normal
sometimes 3rd.
ok the pic below
idle looks normal
sometimes 3rd.
In this pic it looks like the needle is at
650-700 RPM and the red mark is at 375ish.
I idle between 875-925 (cams got me by the *****), just depends where I set it at. Prior to the turbo setup about 650-700ish and after the stock block turbo setup about 750-800ish.
OP needs to do the idle re leearn ecu reset, thats all.
Groudning kit has little to do w it i suspect.. google search technosquare 350z ecu reset.
USE A STOP WATCH. guessing or counting 1-1000 will not work.
I have done these learning for all of them, you don't need a stop watch, a good 1000 count worked fine
liqalu04
Jan 2, 2022 12:58 PM
Justin100
Nov 29, 2015 03:58 PM
