Flywheel
Old Aug 31, 2004 | 09:20 AM
mzack's Avatar
mzack
Default Flywheel
I am looking at getting a new flywheel. Looking at NISMO and JWT. What is the best for the weight and are there others that someone would recommend?
Old Aug 31, 2004 | 09:35 AM
GPorsch's Avatar
GPorsch
Stillen also offers aluminum flywheels.
Old Aug 31, 2004 | 10:03 AM
ACEMAN's Avatar
ACEMAN
Master
And dont forget JUN, they have a nice flywheel aswell.
But from what i have been reading, the tilton flywheel and clutch is the best to go with. But it is also the most expensive.
Laterz
Aceman
Old Aug 31, 2004 | 12:01 PM
TheBigShow's Avatar
TheBigShow
i'm plannin on a jun flywheel/nismo clutch combo. ace, u weren't up in gettysburg on friday, were u? i happened to see a db z then.
Old Aug 31, 2004 | 02:01 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
JWT FLywheel and NISMO CLutch...
that is the lightest combonation for clutch and flywheel...
Old Sep 1, 2004 | 04:45 AM
ACEMAN's Avatar
ACEMAN
Master
Was not me
So you live in Gettysburg?? Thats not to far away. Next time we all goto the Mason Dixon Drag strip you should come.
Laterz
Aceman
Old Sep 1, 2004 | 05:53 AM
Hazade's Avatar
Hazade
i saw the vid of the tilton flywheel. that thing REVS ! I would recommend that
Old Sep 2, 2004 | 12:51 PM
alininger2001's Avatar
alininger2001
Isn't the tilton flywheel and clutch the lightest. I've heard the stock clutch and th Nismo clutch weigh about the same, but I could be wrong. When I take the plunge I will probably go JWT flywheel with stock clutch. I don't plan on having enough horsepower to warrant a new clutch, but I would love to have the flywhhel.
Old Sep 2, 2004 | 02:40 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
actually I think the Unorthodox is the lightest standalone flywheel you can buy
Old Sep 3, 2004 | 06:09 PM
HankVQ's Avatar
HankVQ
What kind of power can the nismo clutch handle?
Old Sep 3, 2004 | 07:26 PM
PhoenixINX's Avatar
PhoenixINX
fewl
Old Sep 4, 2004 | 06:39 AM
McBickBick's Avatar
McBickBick
How much power can the tilton clutch+flywheel handle?
Old Sep 4, 2004 | 03:06 PM
ReavTek's Avatar
ReavTek
Isn't the tilton flywheel only 8lbs? Seems way too light for me :P I'd be scared. I would recommend the JUN weighing in at about 14lbs. I think stock it's 31lbs... and I know the Nismo one is 28lbs.
Old Sep 4, 2004 | 03:25 PM
Jason@Performance
Performance Nissan
tilton flywheel and clutch set ups range from 360 to the crank up to 1300 to the crank...
Old Sep 4, 2004 | 03:27 PM
axxizzer's Avatar
axxizzer
hmm, I think I'd get the JWT
Old Sep 4, 2004 | 06:45 PM
Jason@Performance
Performance Nissan
UR is lightest when you dont count the flex plate they include from an AT...
the lightest i believe is the 13lb stillen... that can be used with a stock clutch...
but really any flywheel you bolt up to a stock size clutch isnt much of a difference... because the stock clutch / nismo clutch / jwt clutch still weights a ton... the nismo clutch is the lightest though of the stock size..
i posted the sizes some where...
nismo clutch / jwt clutch will handle well more than the VQ and Trans can handle... about 600RWHP...
but... if your going ot be pusshing that much horse power, your not going to care about a streetable clutch and would be talking to me about a tripple carbon carbon clutch or 3 disc cindered steel clutch
Old Sep 5, 2004 | 04:17 PM
redline350ZZ's Avatar
redline350ZZ
The Tilton isnt a childs mod for the Z......LOL...... it changes the car and driveability signifigantly........Driving is almost a chore from a stand-still... but after 1st watch out cause its a blast to drive.....plus isnt a (5.1) 0-60 time....(maybe better) on a N/A car with mild mods just great.... as soon as it get the 3.9 final drive (4.8) 0-60 will be even better...
Also be prepared to buy a lot of rear tires...... and good wide tires too...
Old Sep 5, 2004 | 05:14 PM
lovetoclown's Avatar
lovetoclown
I'm with you on this. The tilton is the best clutch/flywheel once you get rolling. Hit the gas and the back end sinks, the front end lifts and you get sucked into the seats. It makes the Z feel like a turbo. But starting out is a challenge to say the least.
Dr.Paulyy
Jul 29, 2019 07:45 AM
RyansZ33
Sep 15, 2015 05:54 AM
