Custom Earthing/Grounding system Installed...
Old Oct 26, 2002 | 11:41 AM
  #61
nizl's Avatar
nizl
Originally posted by acid burn
Someone asked: if the wire's so cheap, why didn't Nissan install it at the factory?
Probably the same reason the base stereo uses $0.0000035 speakers, and the nav door is flimsy. Nissan had to cut costs wherever possible. How many people even knew what a grounding system was before reading this thread? I sure as hell didn't. If a car came with one from the factory, I'd be like "whatever".
Old Oct 26, 2002 | 11:52 AM
  #62
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
the nissan (nismo) grounding kit is available as an option in japan. just like kick plates, trunk mats, etc...
m
Old Oct 26, 2002 | 12:26 PM
  #63
Scafremon's Avatar
Scafremon
I had never heard of one before. But now, I tell my coworkers "Yea, I'm thinking about putting in a grounding system", to which they reply, "huh?", and I proudly turn into "Mr. Mod", and explain what it does.
Fortunately, they don't ask any specific questions.
Old Oct 26, 2002 | 01:04 PM
  #64
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
Originally posted by GUido
Looks nice. One question, do you tin/solder the wire ends before you crimp them?
i just spoke with him as yet another kit needs to be made
i asked about soldering the wires, and he said it would be $30 extra. this is due to the fact he solders after crimped, so it cant back out. he drills a hole through the hard solid copper, and fills it in.
also, he said if you want a kit wire-loomed, it is $20 extra. you could buy the loom seperate and install it on the wire yourself for $10.
michael
Old Oct 26, 2002 | 08:35 PM
  #65
GUido's Avatar
GUido
michael
Cool, I'm considering it.. have to see if making my own is worth while first
I do have to say I've never heard Copper called hard before... Steel = Hard, Copper = Soft. I've drilled through 4" thick steel before, copper is like going through butter.
Old Oct 27, 2002 | 03:46 AM
  #66
Clyde's Avatar
Clyde
Default connecting points
Does the wire from the battery connect to the point located at the front of the engine or at the point by left header? Based upon that response then the ground to the frame would be connected to the opposite point. Also does it even really matter?
Thanks
Old Nov 30, 2002 | 12:41 AM
  #67
grebmohr's Avatar
grebmohr
Thumbs up
Blue Wires are great!! Looks really good.
Just an additional note, If you can, TIG weld the lugs to the copper cables so your connection will be IRON CLAD. keep the amperage low so you dont vaporize the copper.
I made cables for a living years ago and we would always weld the connectors on.
GL
Old Dec 1, 2002 | 01:33 AM
  #68
3502GO's Avatar
3502GO
I'd like to order a set.
Old Dec 1, 2002 | 05:38 PM
  #69
alex30327's Avatar
alex30327
Does anyone know where you can buy colored Monster cable 4 gauge?
Old Dec 1, 2002 | 09:15 PM
  #70
grebmohr's Avatar
grebmohr
Monster should be available at HIFI Buys. S4B-125 is blue 4 ga power wire S4S-125 would be silver "ground". Electricity is pretty much color blind. there may be other colors available but not sure.
GL
Old Dec 2, 2002 | 07:37 AM
  #71
MSOsr's Avatar
MSOsr
I WANT ONE! Blue, please. Let me know how to pay.
Old Dec 4, 2002 | 12:54 PM
  #72
MSOsr's Avatar
MSOsr
SKidaZZLe:
I want to purchase a Daytona Blue set from you. Please let me know how to do so.
Old Dec 4, 2002 | 07:11 PM
  #73
fdao's Avatar
fdao
Originally posted by MSOsr
SKidaZZLe:
You should email or PM him. You'll get a better response . I paypaled him for my kit and hopefully will be getting them sometime next week .
Old Dec 26, 2002 | 05:52 PM
  #74
Eric1h's Avatar
Eric1h
Does anyone here read Import tuner? If not, go spend the $3.95 and pick up Decembers, it has a whole article on grouding kits and how they DO ACTUALLY work, they have dyno numbers from 4-5 different cars. The gains were anywhere from +.8-15.3hp
Hows that for proof?
Old Jan 9, 2003 | 08:56 PM
  #75
grebmohr's Avatar
grebmohr
Smile A few thoughts for the skeptics.
I have yet to build a set for my car but I will as soon as I get to a Monster dealer.
Electricity is a very wierd beast. My Uncle, an electrical engineer, would swear a paper clip could effectively ground an entire engine system. This may be true under ideal conditions.
I have seen posts about flashlights and extra grounds not making the light brighter-- BS-- put alittle of that corrosion crud on the contact and see what happens to the light. then add a new ground-- hmmm see the difference? try it. Ever have a 20 year old volkswagen with a slow starter? check that longggggg wire from the switch to the starter solenoid-- It has high resistance. Ever have a car that mysteriously lost power after driving for an hour on the freeway?-- check the coil it has high resistance when hot. Not to say that Nissans ground is corroded or will corrode, but that resistance does make a difference in electrical performance- period- that should not be debated at all. Electrons travel at about 100 micrometres per second. Considering that all engine components must be syncronized from the battery/alt through the computer commands to ground, then it makes tremendous sense that the more and better grounds, the better the synchronization would be. i.e. smoother running, better throttle response and an incease in peak power(slightly). Remember, almost all Pos. connections have a dedicated feed but most Neg. connections go common somewhere in the system.
Think it through some more, imagine more electrical situations and I am sure you will see the electricity behaves very differently in different types of circuits. And yes, Using a high grade of very pure copper speaker wire sounds better than a 3 dollar roll of crap from the shack. <---IMHO
Old Jan 10, 2003 | 12:14 AM
  #76
zland's Avatar
zland
Sport Z Magazine
Default Yes, they are that cheap!
Some discussion concerning Nissan would install the grounding kit if it only cost a couple of bucks per car and it worked:
The sad truth is they do cut corners like that as all manufactures do. I tour the Nissan design center every year and about 3 years ago, a designer there told me they cut a really attractive headlight design that all of the people on our tour loved because it had a cost increase of something like $12 per car. If they will cut an item like that knowing it is an item that attracts greater sales, then cutting cost of a $5 grounding system that even Z enthusist like ourselves cannot even decide if it is functional or not seems more likely than not. Lets face it, is there anyone of us that would say "that is it, I am not buying this car, it does not have a grounding kit"?
Another issue is why would NISMO offer it if it did not have merit? Does anyone know if grounding kits are commonly offered in other products?
Well that is my 2 cents!
Old May 1, 2003 | 11:08 AM
  #77
RenaultFreak's Avatar
RenaultFreak
One question: Why is all this earthing/grounding theme so important? Is there an official Nissan letter about this? I think most new cars (I used to own a SpecV Sentra) are well earthed...is this lacking on the 350Z????
All I see on the pics is a bunch of wires going to the same place, I'd earth once for the engine and once for the tranny.-
Is there a link about this?
Thanks.
Old May 2, 2003 | 10:55 AM
  #78
zperfect's Avatar
zperfect
Default grounding kit
hey i know this is a dumb question but
when you install these wires are you also
taken off the old ones?
sorry for the dumb question but not sure.
Old Jul 27, 2003 | 10:29 AM
  #79
uklooney's Avatar
uklooney
Since you aren't getting any money from this can you please take some photos and also write down where the wires lead to and the lengths so that people like myself who have the ability to make them can.
In other words, how did you find out the lengths needed and can you post them.
Yeah, a post of the lengths would be good.
P.S. Will the same cables lengths fit a JDM/UK spec car?
Old Jul 27, 2003 | 11:08 AM
  #80
Redline350zTour's Avatar
Redline350zTour
One thing I would suggest is to run a ground wire to the exhaust pipes near the oxygen sensors. Since this is another important and high frequency input into the ECU, it should improve things even further.
Hey Skidazzle,
Is there any way that your tech guy can try this to see if this does work? If it helps things even more, then you can go ahead and put me down for a red kit (no matter if you have to raise the price do to adding another wire).
