3rd gear grind how can i get this fixed
Old Sep 26, 2004 | 11:01 PM
GTO2350's Avatar
GTO2350
Default 3rd gear grind how can i get this fixed
first off i bought my car used from a nissan dealer with 13400 miles on it i now have 16600 miles on it and just recently started getting the 3rd gear grind after i shift into 3rd after 3500rpm. does nissan cover the transmission untill a certain amount of miles w/o purchasing a extended warranty? how would i go about having this problem fixed without having to come up with money out of my pocket?
thanks
paul
Old Sep 27, 2004 | 02:22 AM
seanrulz's Avatar
seanrulz
If you bought it from nissan dealer, it should be certified right? And even if it isn't, it only has 16600 miles. You are still under warranty and I'd say just go to dealer and get the transmission replaced. It'll be covered under the warranty and you won't pay a penny.
And try go get a new cluch/lightweight flywheel so that you can save on the labor.
Old Sep 27, 2004 | 06:15 AM
mpol99's Avatar
mpol99
Yup, it will be covered by warranty. Go to the dealer and get your transmission replaced!
(I'm on my 3rd transmission at 17,000 miles )
Old Sep 27, 2004 | 06:46 AM
Bahraini350Z's Avatar
Bahraini350Z
Does anyone have the TSB for that??
Old Sep 27, 2004 | 06:53 AM
zectasy's Avatar
zectasy
grinding in 3rd? my way to fix that was to let nissan give me a new tranny
Old Sep 27, 2004 | 08:01 AM
GTO2350's Avatar
GTO2350
so even without purcahsing any warranty on a used car the transmission is covered? because when i purchased the car it did come with a limited warranty but the duration of warranty was only 90 days or 3000 miles.
Old Sep 27, 2004 | 08:11 AM
MRfire's Avatar
MRfire
I got the grind too at 16k miles. Problem is....I can't reproduce it when I'm at the dealer
It only really does it in the morning when it's cold. I would imagine it will get worse so I'll just wait. It should be covered under warranty for 60k miles, no?
Old Sep 27, 2004 | 09:18 AM
zectasy's Avatar
zectasy
hmmm i bought mine used also with 5 k miles on it and at 6k miles thats when i got the grind...i have a normal warranty with mine also...take that ***** in to the dealer..worse comes to worse just upgrade to the JWT clutch and flywheel
Old Sep 27, 2004 | 09:30 AM
roydiculous's Avatar
roydiculous
The powertrain warranty is 60,000 miles/5 years. Doesn't matter if you are 1st owner or 50th owner.. it's transferable.
Good luck as I know I'm annoyed as hell when there is something wrong with the Z until it's fixed!
Uriyo_
Sep 8, 2021 08:46 AM
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
