Welding the Borla True Dual?
Old Dec 7, 2004 | 07:31 PM
350zWarz's Avatar
350zWarz
i put high temp silicone on mine....no leaks to my knowledge
Old Dec 7, 2004 | 07:48 PM
kgb's Avatar
kgb
How was it applied? It makes sense to use some sort of sealant on the pipes before fitting them together to be clamped.
Old Dec 7, 2004 | 08:08 PM
350zWarz's Avatar
350zWarz
i put it on top of the pipe that slides into the other and after i slid them together, i put a little more on the part where the slits are and then clamped it down onto it...
Old Dec 7, 2004 | 08:11 PM
kgb's Avatar
kgb
What is this product exactly and where can I get it?
Has anyone had weld job done that permits the muffler to be removed like this one: http://www.afterhoursautomotive.com/...wCars-G35.html
Old Dec 7, 2004 | 08:55 PM
350zWarz's Avatar
350zWarz
i just went to the auto store and got the silcone with the highest temp rating, don't remember the name
Old Dec 7, 2004 | 08:59 PM
BENJ-AMG's Avatar
BENJ-AMG
This may sound stupid, but how do you know if you have leaks? Is it an audible issue or do you notice a decrease in performance? My Borla has been on for about 2 months now and it kicks azz. Should I check it at a particular point to make sure there are no leaks and, further, how do I determine if there are any?
Old Dec 8, 2004 | 12:21 PM
G3po's Avatar
G3po
Default leaks
Slight leaks can be noted by "carbon tracking" around the joints.
This appears as a litle black film around those joints. These type of minor leaks hurt nothing and can seldom be heard.
Old Dec 8, 2004 | 01:12 PM
etx's Avatar
etx
You could also try Exhaust pipe adhesive.
Old Dec 8, 2004 | 01:16 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
speaking of leakage, what is going to happen when it leak? how do we know? by the sound?
Old Dec 8, 2004 | 01:47 PM
havabooz's Avatar
havabooz
mine has a leak and you can hear it loud and clear...if you cant hear anything just check all the joints to see if there is black deposits around it
if there is, then you have a leak
Old Dec 18, 2004 | 02:35 PM
kgb's Avatar
kgb
...had the exhaust leaks on my Borla sealed up today. The joints forward and between the H pipe was where the major leaks were. The mechanic welded these points and tightened the clamps elsewhere.
It's amazing how these small leaks affects how the engine runs. Mechanically, it's quieter and runs a bit smoother; I now hear more exhaust sound and less mechanical noise. Even the Pop Charger is louder than before.
If you have exhaust leaks, get it sealed up.
Old Dec 18, 2004 | 10:27 PM
mlemieux137's Avatar
mlemieux137
i got mine spot welded on all the clamps because it was rattaling. now that problem is solved but it creeks when i take it out of 1st gear??...not everytime just sometimes. other than that its a great mod
Old Dec 19, 2004 | 01:30 AM
tcfool's Avatar
tcfool
Had mine clamped down with an impact wrench and so far so good.. I will check for leaks every now and then and if it happens then my bud will spot weld it... I love the new sound....... Just enough for me...........
TC
Old Dec 22, 2004 | 05:42 PM
Shift_Daytona Z's Avatar
Shift_Daytona Z
why would you have to cut the joints to remove the exhaust. I was just underneath the car and it looked to me like all you had to do was take of the black triangular body tie off of the rear, remove the exhaust from the rubber hangers and then it would just drop down.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Apr 28, 2017 09:00 PM
